RC10 On Road Conversion
- Atlas
Hello All, trying to put together a six gear RC10 for running on smooth surfaces and have some of questions. I was hoping members here could help me out.
Here is what I have/like to use:
Six Gear RC10 w/ short front arms and one hole front/rear shock towers from Re-release kit
Andy's oval rear body mount
Custom Works dirt oval form tires
Custom Works Open Comp Camaro body or Custom Works Street Stock Camaro body
Here are my questions:
01. What is a good front body mount to use for those two Camaro bodies mentioned above? I'm aware of Andy's, RPM, JG, and Speedy, but are there other ones on the market?
02. Will I need a lowering kit to run either of those two Camaro bodies? Will those two bodies clear the stock shock towers without giving me a lifted/off road look? If a lowering kit is needed, which kit works best? From what I gathered lowering kits are available from JG, Bolink, Mcallister, and Speedy. Are there other options?
03. Will the wheels stick outside of the car body? I will be using a Custom Works 0.125 spacer on the back using 3/16 axles.
04. On a side note, I know there are a few pan car front end conversions kits for the RC10 (i.e. Lucas Agitator, Hyperdrive, etc), but was there ever one that uses a RC10L front end? Also could you mount a 235mm GTP bodies with these conversions or will it not clear the transmission/rear shock tower?
Thank you in advance.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Re: RC10 On Road Conversion
01. Bolink made a body mount kit for on road/dirt oval bodies too. Not usable with a McAllister lowering kit if you go that route though. Your best option would be an "oval" bumper from Andy's, JG, or RPM that have holes for body mounts. They'll give the most body support.
02. You'll at least need to cut down the rear shock tower to use short shocks and add some limiters inside the front shock bodies. Dirt oval street stock and late model are built with taller sides than 10L style pan car GTP bodies so you might get away without needing a front lowering kit.
03. Not sure on this one but my guess is they will a little.
04. J-Car made one that used the old 2 hole 12e/i/l front arm mounts. Much later on Lightz made some with left offset batteries for oval racing. These conversions were good at mounting pan car bodies at the front but not great at the rear for GTP bodies. Especially if you wanted to use 2" wide pan car foams. Rear shock towers would get in the way and rear wheels would stick way out.
- Atlas
Phin, thank you so much for your detail information.
Would anyone know where I could find a template for cutting/drilling new mounting holes to shorten the rear shock tower?
you could actually use a DS rear tower, which would also have a rear body mount set on it.
I think there might be a rcca article for on-road conversion that might have a drawing of a modified tower, but not sure.
you can stack one tower on another to use as a drill template, you just need to figure out how low to go.
This was the setup I used to run and I had no clearance problems with a body - even without trimming the front tower. Although it seems as if all bodies I was finding were too narrow for my liking.
Especially in the front...perhaps a short art car might fair better...
With that being said I decided to go with a standard buggy body...Here I trimmed the front towers so it looked better
-Mike
RC10T | Kyosho Lazer ZX - 55mph | Mid Motor RC10 Pan Car Conversion - 72mph | OIN RC10 spare/used parts build - 69mph | 4x4 MonsterT build
86 ascMcLaren Capri 5.0 | 86 Mustang SVO
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
Nice looking roadster, but I thought that black RC10 looked familiar! http://www.rc10talk.com/viewtopic.php?f=37&t=36701&start=30 As it turns out, I'd seen it before. Must've made an impression on me.
Matt
Nice! I never did check on those connectors for you...sorry. But I'm confirming now I did sell them. lolmatt1ptkn wrote: ↑Wed Feb 08, 2017 8:44 am Nice looking roadster, but I thought that black RC10 looked familiar! http://www.rc10talk.com/viewtopic.php?f=37&t=36701&start=30 As it turns out, I'd seen it before. Must've made an impression on me.![]()
-Mike
mikemartinelli.com
My Shapeways Stuff
mikemartinelli.com
My Shapeways Stuff
- matt1ptkn
Matt
- Phin
Can't believe I forgot about the Slam Dunkin lowering kit: http://www.rc10talk.com/viewtopic.php?f=35&t=26614&start=45#p312099
Super rare but given your talents for making aluminum parts it should be a snap for you to reproduce something similar. Maybe churn out a short run of them for others while you're at it.
- lmw94002
- Been thanked: 9 times
A long time ago a guy had a crazy idea and I only saw part of his prototype for the transmission class on the flat carpet oval...
He took the front part of an old 10L style pancar chassis and put it on an RC10 tub. Essentially hacked it up made a nose-plate that bolted up to the tub that had the newer 10L front end. That gave your RC10 a pan car frontend ... not really sure what he was going to do w/ the rear.
--Builds--
--Builds--
- 952 Views
Last post by THEYTOOKMYTHUMB
- 55 Replies
- 5669 Views
Last post by tyhodge07
- 1038 Views
Last post by therigliveson
- 23 Replies
- 3402 Views
Last post by SMOKE-DOG
- 1278 Views
Last post by Prince Steve
- 1285 Views
Last post by aconsola
- 1608 Views
Last post by LTO_Dave
- 626 Views
