trackmaster belt pitch?
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Hi folks,
Does anybody know what pitch is the trackmaster belt?
Any sources to buy different lengths of this belt type are welcome too.
- highwayracer
- Been thanked: 6 times
Re: trackmaster belt pitch?
If I remember correctly, the track master belts were almost twice the width of the standard belts of that time (like on the optima mid). The pitch was also larger...similar to the ones on the optima mids.
Regards,
highwayracer
Regards,
highwayracer
- Mr. ED
The pitch is larger than the metric M3 indeed.
I suspect it to be an imperial pitch size (like the A&L belts except that pitch is smaller than M3)
The optima mid belt is also metric I guess since kyosho is in japan where imperial ptiches are not the standard. It kind of looks like M# teeth, but with a wider spacing between them.
Still would like to know waht the Trackmaster pitch is called and where I can find a supplier for a longer belt.
My plan is to build a one-off 4wd with the main chassis build up from 2 verticalplates serving at the same time as gearcases for the front and rear, with one belt running over the pulley and both diffs.
I know , pretty ambituous but I'll take my time to finnish it.
Just need to find that belt before I start though.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Ed, I wish I knew the pitch...that is the same idea I have had for quite some time. AYK Radiant style homebuilt car.
- Been thanked: 12 times
Mr. Ed,
Do you have a standard trackmaster belt and just need to know what the belt pitch is called (can't help you there),
or are you looking for measurements from someone who has a belt? I've got a NIP belt in a rebuild kit that I could measure up if that is the case.
nevermind the last post. I think I found what you need .
I measured my new belt(unfortunately no markings on it), and this is what I got:
Width: .25"
Teeth 25
Length ~5"
Pitch .2"
Overall thickness at tooth .089" (2.3mm)
Thickness in "valley" .041"
Googling a few search terms comes up with this PDF:
http://www.sdp-si.com/D790/PDF/D790C02051.pdf
the standard belt appears to be an "XL" ptich
Width: .25"
Teeth 25
Length ~5"
Pitch .2"
- Mr. ED
I have the original belt (by now own 2 ultima versions and 1 rc10 version)
Thanks for the measurements though, being in inches they may help me find the right stuff on some manyufacturers site.
The company I got the info from above has an e-store:
https://sdp-si.com/eStore/
If you click on belts&cables then timing belts you will get a large selection.
narrow by selecting "single sided," XL pitch, and 1/4" width, and you will have 289 belts to choose from. No minimum order and they ship inernationally.
good luck.
good luck.
- Mr. ED
Big thanks Anthony,
I overlooked the second part of your previous post (probably paid no attention thinking it was the signature
Now I got the belt type and a supplier I can start working ihe concept out a bit, may try to get the chassis parts modeled in CAD and have them cnc'ed. Ooo this wil be a huge project.
Bad timing though: the company is calling me back to my home-country giving me lots of head-aches and from the end of next month, for 8 weeks minimum, all RC will sit in a container on a boat
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
OOOOFFF! Don't do that to your poor r/c...send them to me and I'll hold them for you til you need them on a nice oval...err, I meant in a clean environmentally controlled climateMr. ED wrote: for 8 weeks minimum, all RC will sit in a container on a boat
Have a good transition...
- Mr. ED
- 831 Views
Last post by elb75
- 21 Replies
- 4684 Views
Last post by blubblood
- 2213 Views
Last post by kaszal
- 1398 Views
Last post by mamadoesntletme
- 1539 Views
Last post by Dadio
- 1414 Views
Last post by LaserRC10
- 2670 Views
Last post by RichieRich
- 34 Replies
- 3889 Views
Last post by treehugger
Users browsing this forum: Dangeruss,
Google Adsense [Bot],
Google Feedfetcher,
Incredible_Serious,
juicedcoupe and 6 guests
