I have some rims that I can't use because the RC10t axles aren't long enough to be able to get the axle screws on. Are these "axle extenders"?- will these work?
Thanks
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=200257195170&ssPageName=STRK:MEWA:IT&ih=010
Will these work?
- highwayracer
- Been thanked: 6 times
Re: Will these work?
I don't think those will work. I'm assuming that you either have an A&L wheel or some type of wheel that was designed for a blackfoot.
If this is for the front wheels, there are extended axles out there. However, they usually require 5mm bearings.
For the rear wheels, there is an extension nut that can be used so you can keep the stock rear axle.
If you post pictures of the wheels, I'm sure that others can also provided information.
Regards,
highwayracer
Regards,
highwayracer
- 585 Views
Last post by JK Racing
- 1206 Views
Last post by tomolupus
- 1038 Views
- 749 Views
Last post by n33no
- 1169 Views
Last post by stulec52
- 43 Replies
- 8713 Views
Last post by Lavigna
- 2894 Views
Last post by airbats801
- 1077 Views
Last post by Erich Reichert
