Stock RC10 tire replacement?
- call-911
Is there a knock off tire that at least looks similar to the stock RC10 front and rear tires? I'd like to put some new shoes on this BEAUTIFUL box stock car I just got, but I don't want to put 50% of what I spent on the car to go into new tires.
Keith C
- mrlexan
- Been thanked: 12 times
Re: Stock RC10 tire replacement?
Fronts: early cars, you can either use CRP or AYK, if you can find them. Later cars, there really isn't anything that looks close. I would go with Proline three rib.
Rears: Your best bet is AJs or Tamiya Holiday Buggy... they are plentiful. As for the duplicates, early: Proline did make a close set, but I have never seen them anywhere. Late: Traxxas made something identical with no lettering, but again, I have never seen them anywhere.
www.gojammedia.com
www.gojammedia.com
- call-911
Oops, yeah probably should've specified. The original RC10 with the kidney bean wheels. Would anyone happen to know of a source of the tires Jay mentioned?
Keith C
- JPAE07
CRP has an ebay store where they stock the vintage Tamiya rear and front tires
- call-911
Thanks, I'll keep an eye out. No tires currently listed from them.
Keith C
- mrlexan
Good luck on the search Keith, it won't be an easy one.
www.gojammedia.com
www.gojammedia.com
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Put up a picture of what you want, that will help us less knowledgable on the rc10 originals and variations to make a suggestion.call-911 wrote:Is there a knock off tire that at least looks similar to the stock RC10 front and rear tires? I'd like to put some new shoes on this BEAUTIFUL box stock car I just got, but I don't want to put 50% of what I spent on the car to go into new tires.
- call-911
Here are a couple that I found...
- Attachments
- Fronts on this one
- rc10rwb_1.jpg (76.08 KiB) Viewed 1964 times
- Rears on this one...
- Holiday Buggy 3.JPG (161.91 KiB) Viewed 1965 times
- fd89_1.JPG (20.39 KiB) Viewed 1963 times
Keith C
- highwayracer
- Been thanked: 6 times
Hey Kieth,
Traxxas makes a rear tire that's nearly identical to the original Associated tire (the one with Team Associated on the side wall).
Regards,
highwayracer
Regards,
highwayracer
- highwayracer
As many of you know, Associated used a couple of different tires on the original rc10.
There was the AJ's tires that Kieth's last picture shows. They also had the tire with the TEAM ASSOCIATED on the sidewall. Below is a picture of the TA tire (right) next to the Traxxas Cat tire (left).
The TA tire has a little bit of wear, tha's why the tips of the spikes look a little bit larger. One thing to note, is that Traxxas used 2 types of rear tires on the CAT. This one, and another version that has "V" gorves with the spoke. The tires below do not have a part number on the original header card.
Regards,
highwayracer
Regards,
highwayracer
- Mr. ED
I'll keep an eye ou for stuff like this 'round here, not that I can remember seeing it anywhere yet though.
those fronts are similar to tomahawk or scorpion ones. What diameter is the inner bead of the wheel?
- highwayracer
Oh...one more thing...
Another little secret that I've kept to myself is that the original ultima front tires (for the 2 piece wheel) fit the original rc10.
Regards,
highwayracer
Regards,
highwayracer
- MelvinsArmy
- Been thanked: 11 times
Won't re-release Tamiya Hornet tires work? I put some Grasshopper tires on my 1.4 Tecnacraft rears, I just had to trim some of the inner bead off, they fit just fine.
- Mr. ED
It sounded like he was on a search for something which looks closer to originalMelvinsArmy wrote:Won't re-release Tamiya Hornet tires work? I put some Grasshopper tires on my 1.4 Tecnacraft rears, I just had to trim some of the inner bead off, they fit just fine.
- MelvinsArmy
Oh that.Mr. ED wrote:It sounded like he was on a search for something which looks closer to originalMelvinsArmy wrote:Won't re-release Tamiya Hornet tires work? I put some Grasshopper tires on my 1.4 Tecnacraft rears, I just had to trim some of the inner bead off, they fit just fine.
Usually I'm good with the details. Not tonight. I'm going back to the TV.
- 3367 Views
Last post by RC10th
- 3397 Views
Last post by Snaab9-2
- 1132 Views
Last post by Rootdown4594
- 1474 Views
- 1246 Views
- 1663 Views
Last post by veghead211
- 1243 Views
Last post by arf
- 459 Views
Last post by TokyoProf
