Looking for modern replacement for RC10 battery cups
This is for a AYK super trail I'm working on. I will make myself a plate to fix the battery on. I'd like to find some battery holder system similar to the RC10 but with a cum a bit wider for my NiMh batteries. Maybe something from Tamiya or another brand. Can't find what I'm looking for but I'm sure there is something out there...
Any suggestions? Thanks
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Looking for modern replacement for RC10 battery cups
i believe he meant "cup".Lowgear wrote:What a bit wider?
How about the PureTech-type velcro system?
puretechproducts.com
Doesn't look retro, but super functional.
Well I don't really like the velcro approach... I'm hoping to find some type of battery cups..
- Been thanked: 81 times
The RC10 battery cup is 1-15/16 inches on the inside if that helps. Bolt on or good servo tape to mount.
- arf
- Been thanked: 7 times
You could split the AE cups down the middle and double stick them to the chassis at the correct width. Then to fabricate a longer hold down strap should be easy. If you don't like the gap then two cups could be cut and combined to make one wider cup with no gap.
- 6139 Views
Last post by NomadRacer
- 5225 Views
Last post by mk-Zero
- 2069 Views
Last post by SoloGraphix
- 3060 Views
Last post by teman
- 585 Views
Last post by paul
- 968 Views
Last post by naushad
- 23 Replies
- 3121 Views
Last post by JosephS
- 1339 Views
Last post by radioactivity
Users browsing this forum: Tbot [Bot] and 3 guests
