Novak 410 Speed Controller???
tecnica2001
Has thanked: 19 times
Been thanked: 29 times
Post by tecnica2001 »
Does the novak 410 ESC has a motor limit?? Will it handle an 11t trinity speedgems Topaz motor??
Thanks in advance.
carloco8
Has thanked: 64 times
Been thanked: 224 times
Re: Novak 410 Speed Controller???
Post by carloco8 »
Which 410 do you have? Is it a M5, M1, M1c, MXc, or HPc? With an 11t motor, you should be ok as long as its not the M5, which is the sport model and should only be able to safely handle 14-15+ turns, especially if using today's high capacity packs.
RichieRich
Has thanked: 39 times
Been thanked: 24 times
Post by RichieRich »
I have a 410 M5 and I ran a 12x2 for YEARS with no problem. There was never a turn rating on it back in the day.
tecnica2001
Oh darn, I have an M5, I guess I can always use the 19t chameleon that I have.
And slap the GTX if I want to run the Topaz.
thanks guys
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
Don't those have cut-off etc? I thought you could just try and if it doesn't handle the motor it will just shut off before it gets into a problem?
The point about the batteries is a goo done though, the old specs don't count for batteries with triple and more the capacity of the early days.
templeofspeed
Been thanked: 32 times
Post by templeofspeed »
Almost all Novak manuals are available for download...
http://teamnovak.com/download/instructions/index.html
