wel lthis came in a buggy i purchased and i can't finish the modle name
it says NOVAK **1x not sure what that is it has 2 rows of heat sinks . the motor leads & power leads come out the right sid of the case & the switch and reciever plug are at the bottom. it is not push button either.
Novak speed control Identity problem
- call-911
Re: Novak speed control Identity problem
Most likely a T-1X. Big mutha of an ESC, but it was the best in it's day. I got one in an auction and sold it for $25 if I remember correctly.
Keith C
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
On the Novak website there is a timeline and on that it is identified as the NESC-1X which was made up to 1988. Under the downloads you can get the manual, here it is:
http://www.teamnovak.com/download/instructions/pdfs/NESC_1X_Instr.pdf
Hope this helps.
Hope this helps.
This is all very interesting!
- 937 Views
Last post by Kyoshojoe
- 1378 Views
Last post by Racer_X
- 1420 Views
Last post by FlyinGN
- 3829 Views
- 945 Views
Last post by littleVETTE
- 1227 Views
- 4422 Views
Last post by BillKrueger
- 575 Views
Last post by mikedealer
