Novak 4 speed control
FlyinGN
Post by FlyinGN »
I have an old Novak 4 (not a T4) speed control that is mint that I wanna put in my old Hot Trick car... I don't recall the specs on it.. How many turns can I go down to safely??
Frank
templeofspeed
Been thanked: 33 times
Re: Novak 4 speed control
Post by templeofspeed »
FlyinGN wrote:I have an old Novak 4 (not a T4) speed control that is mint that I wanna put in my old Hot Trick car... I don't recall the specs on it.. How many turns can I go down to safely??
Frank
I think you can get pretty radical with that one, like 16T... :wink:
Speaking of old Novaks, anyone know who the manufacturer of the on/off switches was on the old ones? I have a few T series that are missing their switches. :(
I s'pose I could hunt around places like MCM, but if anyone knows... 8)
templeofspeed
And I know someone will suggest this... :P
FlyinGN
Post by FlyinGN »
lol ..... thanks..
carloco8
Has thanked: 74 times
Been thanked: 271 times
Post by carloco8 »
If you are gonna run old batteries like 1200's or 1400's and maybe 1700's a 16 turn should be fine, but if you are going to use newer batteries with 3000+ mah only use a stock motor cuz it'll get quite hot after running so long. Also, be sure to hook up an external fuse to it to be safe.
FlyinGN
Post by FlyinGN »
good points. Thank you sir..
carloco8 wrote:If you are gonna run old batteries like 1200's or 1400's and maybe 1700's a 16 turn should be fine, but if you are going to use newer batteries with 3000+ mah only use a stock motor cuz it'll get quite hot after running so long. Also, be sure to hook up an external fuse to it to be safe.
Users browsing this forum: No User AvatarSeznam [Bot] and 4 guests
