Boyer sand rail
Forum rules
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Boyer sand rail
that's pretty cool, but i don't like how he has the upper shocks mounted. tops and bottoms of shocks mounted opposite of each other is usually only good for one thing.
finding the weakest point.
- shodog
Re: Boyer sand rail
I'm not following you, explain yourself young manscr8p wrote:tops and bottoms of shocks mounted opposite of each other is usually only good for one thing.
- terry.sc
- Has thanked: 7 times
- Been thanked: 157 times
Re: Boyer sand rail
And they were actually a Boyer designed production chassis
http://rc4wdstore.com/product_info.php?cPath=31&products_id=780
- aeiou
Re: Boyer sand rail
Cool stuff...
Here's the chassis:
http://rc4wdstore.com/product_info.php?cPath=30&products_id=816
And another one...
http://rc4wdstore.com/product_info.php?products_id=781
http://rc4wdstore.com/product_info.php?cPath=30&products_id=819
Here's the chassis:
And another one...
Re: Boyer sand rail
shodog wrote:I'm not following you, explain yourself young manscr8p wrote:tops and bottoms of shocks mounted opposite of each other is usually only good for one thing.
alright, lets see...................... do you notice in the pic that the top of the shocks mount from the outside in, and the bottoms mount front to back? how well to you think that shock is gonna pivot when the suspension compresses? the shock is not allowed to rotate freely on the shock bushing on the top. it's more or less rocking back and forth against the nut that's holding it on. which is the best way to destroy a shock. especially if it binds before the suspension is fully compressed.
i suck at explainig this sort of stuff. to me, it's just common sense that the top and bottom of the shock should mount in the same direction. front to back. unless we're talking about the a&l trailing arm setup.
but, hey.............. who am i to say it's wrong. he's the chassis designer/builder.
- Has thanked: 183 times
Re: Boyer sand rail
i'm following ya scr8p. if one of the mounting points doesnt follow the same arc as the rest it will bind, unless there is enough slop to allow for it... right?
Re: Boyer sand rail
ya, more or less.badhoopty wrote:i'm following ya scr8p. if one of the mounting points doesnt follow the same arc as the rest it will bind, unless there is enough slop to allow for it... right?
Re: Boyer sand rail
that's another reason why instead of a normal shock bushing, it has fuel line in it's place.
and to me, that's like putting a band-aid on the problem.
Re: Boyer sand rail
icky shock mounting or not, its pretty cool that its made available to the masses.
you guys remember the old days when it was just hua, and he was in waaay over his head?
rc4wd sure has came a very long way.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: Boyer sand rail
Thats pretty cool...even if its flawed. There's one thing that I have really gained with my short membership here besides the knowledge is all the links you guys come up with. Gonna have to get another pc just to put the rest of my R/C links on
Thanx
Thanx
- shodog
- MelvinsArmy
- Been thanked: 11 times
Re: Boyer sand rail
Boyer mounts all his shocks on the chassis with fuel line. Crawlers, scale MT's, now these things. It actually makes for a really good bushing. I don't know if I'd want it on a high-speed machine that's going to take a lot of beating, but for crawlers and MT's, it works great and allows much more movement of the shock. I do agree about the pivot, there's no reason why the mount couldn't have been made the normal way.scr8p wrote:that's another reason why instead of a normal shock bushing, it has fuel line in it's place.
- bearrickster
- 4899 Views
Last post by rhino1
- 1988 Views
Last post by shagrat69
- 1277 Views
Last post by vintage AE
- 2328 Views
Last post by Dr. Robotnik
- 63 Replies
- 9486 Views
Last post by lexus-5
- 26 Replies
- 6663 Views
Last post by iVTEC4LIFE
- 2116 Views
Last post by Toykid
- 821 Views
Last post by flipwils11
Users browsing this forum: Google Adsense [Bot] and 2 guests
