MY GOLD PANS
COZINATOR1960
MY GOLD PANS
Post by COZINATOR1960 »
Hi,
These were gifted to me by a friend.Image
I have drooled over this car since 1986!
I'd like to go modern on electronics; done winding my own motors.
Budget is tight.
I have yet to drive this model, yet.
All comments are welcome
MY RC10s
MY RC10s
Has thanked: 2604 times
Been thanked: 2977 times
Re: MY GOLD PANS
If you run with the big tires and a modern brushless motor, then the chassis with the stealth gearbox (has no wheels right now) seems like the right one to use. The chassis with the big wheels has a lot of shocks!
Has thanked: 268 times
Been thanked: 2094 times
Re: MY GOLD PANS
Did someone replace the nose tubes with shocks?
8rad
Has thanked: 9 times
Been thanked: 38 times
Re: MY GOLD PANS
Post by 8rad »
juicedcoupe wrote: Thu Mar 20, 2025 7:45 pm Did someone replace the nose tubes with shocks?
Dynamic caster... :lol:
8rad
Re: MY GOLD PANS
Post by 8rad »
I looks like you have one complete car from the parts there minus nose tubes, transmission brace, gear cover, body and wing
If youre on a budget, this speed controller and motor combo should get you rockin. I have bought many of these and they're great for the price.
https://www.amainhobbies.com/hobbywing-quicrun-1060-1-10-brushed-esc-hwa30120203/p1533864
https://www.amainhobbies.com/hobbywing-quicrun-brushed-555-motor-13t-hwa30404316/p1456306
or Brushless
https://www.amainhobbies.com/hobbywing-quicrun-10bl60-sd-g2-sensorless-brushless-esc-qr3650-g2-motor-combo-hwa30803204/p1598533
Good luck with the build.
COZINATOR1960
Re: MY GOLD PANS
Thank you so much guys for the quick response!
These were the answers I was looking for.
Can anyone recommend a budget transmitter+receiver combo for this setup?
Re: MY GOLD PANS
That Hobbywing brushed motor is a 555, 5 slot. It's a slow crawler motor.
But there are plenty of other options.
COZINATOR1960
Re: MY GOLD PANS
Yeah, shocks for nose tubes, lol.
They will be removed.
So will the huge tires.
My goal is: close to stock chassis+ modern electrics.
Battery will be 18650 cells for now.
It will be for fun only, not competition.
A "basher"?
COZ
COZINATOR1960
Re: MY GOLD PANS
Oh,
and the stealth transmission is not working; internal slippage?
COZ
Re: MY GOLD PANS
COZINATOR1960 wrote: Fri Mar 21, 2025 12:26 am Oh,
COZ
The diff might need rebuild, or the external slipper clutch might need adjustment.
8rad
Re: MY GOLD PANS
Post by 8rad »
juicedcoupe wrote: Fri Mar 21, 2025 12:08 am That Hobbywing brushed motor is a 555, 5 slot. It's a slow crawler motor.
Thanks for the correction. Cheers
Re: MY GOLD PANS
COZINATOR1960 wrote: Thu Mar 20, 2025 11:51 pm Can anyone recommend a budget transmitter+receiver combo for this setup?
What is your budget? And what features do you need?
If you are wanting something basic, I prefer (new) takeout RTR parts. They are all over Ebay, most for well below market price.
COZINATOR1960
Re: MY GOLD PANS
Thanks so much gang!
I looked at the stealth transmission on the "double-A" stamped chassis and it looks like the round metal plate(slipper or clutch?) or washer is missing; just a nut, spring and black spur gear. Also, a wheel bearing is seized.
The guy that did the shock bumper mod was a "hack"; he had forced too long screws through the trans brace making cracks in trans case.
I noticed after removing the long screws that I have direct view into the gearbox, thinking of shooting some gear oil in there.
ADMIN: Should I start a new thread since this mechanical?
T.I.A. Y'ALL!
COZINATOR1960
Re: MY GOLD PANS
JUICEDCOUPE:
Budget is tight. Like $100 a month, max. Also, "features"? This will be strictly for play, not competition. Sorry I missed your questions. My previous experience with the R/C world was working in a hobby shop doing sales(1986); always wanted one.
I started with a grasshopper and eventually had KYOSHO TURBO OPTIMA 4WD. Fortunately, I have an Electronics background and I could bring my radios to the RF lab I worked in. :D
Thanks for your time and help; it is much appreciated!
COZ
COZINATOR1960
Re: MY GOLD PANS
Oops! Correction: the gold pan with 3 gear transmission is stamped: "B".
Pic I took closeup of spur gear "image size too large" to upload. So, imagine just the plastic gear, no ball bearings or retainer plate that would be held by the compression spring and nylock nut.
If I turn the gear by hand, right side drive turns, only. Thanks to a member mentioning that stealth transmissions are available on ebay. :D
COZ
