Kamicosmos RC10 4WD Build
- Been thanked: 17 times
This thread is for my RC10 4WD build.
1993 RC10 Championship Car
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Re: Kamicosmos RC10 4WD Build
Pretty neat to see a Front Stealth transmission!
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Electronics arrived. Went all Reedy, figured since the OG car and the RB10 are all reedy, why not? I was eyeing some of the Castle products (they're somewhat local to me), but I also am still learning all the terms, slang, techniques of all this new 'fancy' brushless stuff. Plus, I when I add things to my hobbies, I have this weird 'need' that they need to be 'For Something'. In this case, I could technically run this at the local track in the 4WD buggy class, right? So, therefor I need a ROAR approved motor and esc for Stock class, right? Hence the Sonic 540 13.5T Fixed Timing motor and matching speed controller. And, even though I have other batteries, none of the other cars run the battery horizontally, so I needed a Shorty...
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Rear Stealth Transmission build! Neat seeing the belt drive on there. (I didn't know about the after market third party conversion kits till I got this car, and came here and read about it. So, I feel a bit bad about having this kind of weird counterfeit-yet-official car. But, I always wanted a 4WD RC10, and they didn't exist when I was into RC the first time, and of course, as previously mentioned, I just came back in, so...
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Other side with the 81 Tooth spur gear and the slipper clutch. I'm going to pair it with a 18t pinion gear, see how that works out.
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
The two transmissions, together! Ready to rule the track as ... uh...father and son? ...
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Not sure if Decepticon or front shock tower and arm mounts...
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Front drive shafts assembled
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Front hubs assembled
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
and mounted in the car. I kept putting the shafts in the outputs, but of course every time I move the car, they slide out. so... yeah.
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Well, I got focused on this session, and managed to forget to grab pics of the subassemblies going in the tub.
But here's the chassis stiffeners, rear bulkhead, shock tower, and transmission all mounted in the car.
Also, installed and adjusted the belt. Moving right along!
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Front end is tight! Has a lot of stuff crammed in there.
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
Overhead view. Next up is rear arms, a lot of turnbuckles to build and adjust, and then on to the shocks.
2024 RB10
2025 RC10 4WD
2024 RB10
2025 RC10 4WD
- 2577 Views
Last post by delsami
- 1108 Views
Last post by soniccj5
- 572 Views
- 93 Replies
- 23848 Views
Last post by Jeep-Power
- 474 Replies
- 52855 Views
Last post by foampervert
- 19 Replies
- 3106 Views
Last post by covell2
- 823 Views
Last post by vintage AE
- 2117 Views
Last post by Carknowledge101
