Cougar 2 Works Confirmed!
- Has thanked: 1782 times
- Been thanked: 859 times
Re: Cougar 2 Works Confirmed!
Me when Thunder Tiger released a dozen RC10 variants
Me today when Schumacher announced the C2
The C2W transmission uses the same belt as the standard transmission, which means we have an easy upgrade path to add a slipper clutch to the early cars.
Resourceful, energetic folks always had a solution by piecing together bits from current cars and printing a pulley to add a slipper. But now lazy folks like me can just order U8703. The top pulley is the weakest link in the TC and Cougar re-res, so the 1 piece alloy layshaft solves that issue as well.
- LurkingCAT
- Has thanked: 202 times
- Been thanked: 271 times
Some nice parts emerging on the horizon. Looking forward to roller driveshafts, pro shock bodies, slipper pulley, F&R roll bars etc
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2978 times
I'm wondering if one of these 2wd aluminum pan buggies could have a Schumacher 4wd setup transplanted into it. The biggest part of that question is how different are the rear gearbox mount setups? I know there would need to be a belt pass through hole.
If anyone could do it, it would be you.Frankentruck wrote: ↑Fri Dec 06, 2024 10:04 am I'm wondering if one of these 2wd aluminum pan buggies could have a Schumacher 4wd setup transplanted into it. The biggest part of that question is how different are the rear gearbox mount setups? I know there would need to be a belt pass through hole.
- Frankentruck
It might end up just being a Cougar chassis pan under a 4wd buggy.
Here are the plans I drew up for a 4WD Top Cat with the Losi 5 link rear if you want to use them:
- Frankentruck
Don't let Schumacher get ahold of these plans! It could be disastrous for them!
Meanwhile....in England...Frankentruck wrote: ↑Fri Dec 06, 2024 11:18 amDon't let Schumacher get ahold of these plans! It could be disastrous for them!![]()
- Has thanked: 665 times
- Been thanked: 473 times
The mounting positions are way different or you could mid mount the cougar box and mod it to 4wd but why bother. you’d just buy a xls or procat where the hard stuff has already been worked out on a platform that was made for 4wdFrankentruck wrote: ↑Fri Dec 06, 2024 10:04 am I'm wondering if one of these 2wd aluminum pan buggies could have a Schumacher 4wd setup transplanted into it. The biggest part of that question is how different are the rear gearbox mount setups? I know there would need to be a belt pass through hole.
- 24 Replies
- 5548 Views
- 36 Replies
- 5971 Views
Last post by Bormac
- 3536 Views
Last post by DerbyDan
- 3301 Views
Last post by yorak
- 2386 Views
Last post by 8rad
- 1746 Views
Last post by hkp
- 1771 Views
Last post by moozo
- 30 Replies
- 5494 Views
Last post by Momo5
