Team Losi advertising some of their more popular items, from tires, motors, and gears, to the JRx Pro SE buggy and LX-T Truck in 1992:
Wheels:
3-Piece JRx-T
5-Spoke JRx2
Losi Logo JRx Pro & JRx Pro SE
Tires:
Ribbed Front Truck
6 Row Spike Rear Truck
Knobby Rear Buggy
X-Pattern Rear Buggy
Staggered Rib Front Buggy
Ribbed Front Buggy
Motors (in order):
6105 - Daytona - 13x3
6103 - Jr's Choice - 17x2 and 17x3
6106 - Motown Missile - 12x1
6104 - Monster Truck Motor - 19x2 and 18x4
6060 - Super Stock - 27x1
Vehicles:
JRx Pro S.E. - Released in 1992 as the last iteration of the JRx 1/10th 2wd electric off-road buggy. lighter and narrower adjustable wheelbase molded composite chassis. Longer swept a-arm/turnbuckle camber link front suspension. Short front/extra long rear Hard Body oil-filled coilover shocks. Black fiberglass shock towers. High angle tie rod ends. Ball-diff, LRM trans with higher temp gears and updated slipper for use with Losi's new Hydra-Drive. Telescoping universal joint axles. Losi Logo wheels with HT X-pattern rear tires and HT Staggered front tires. Full bearings. New Slim-Line clear lexan body. Unassembled kit sold without radio and electronics.
LX-T - Released in 1992 the 1/10 2wd off-road race truck was an evolution of the JRx-T. Used a JRx Pro S.E. composite chassis, longer, lower a-arms/turnbuckle camber links, and new caster/steering blocks. Longer rear h-arms, turnbuckle camber links and hub carriers. Revised composite shock towers front and back, Hard Body oil-filled coilover shocks with adjustable spring collars. Ball-diff LRM transmission with high temp gears, aluminum motor mount and updated slipper clutch to work with Losi's new Hydra-Drive. Longer universal joint telescoping driveshafts. Single piece 2.2 plastic truck wheels with clear lexan dust caps, 6-Row Spike rear tires and Ribbed front tires with full bearings. Super low clear lexan truck body. Sold as an unassembled kit without electronics or radio.
Team Losi Choice Of Champions 1992
- Dangeruss
- Has thanked: 425 times
- Been thanked: 1411 times
- 296 Views
Last post by Dangeruss
- 499 Views
- 231 Views
- 806 Views
Last post by Chewbacca
- 288 Views
- 2653 Views
Last post by Marshky
- 774 Views
Last post by V12
- 923 Views
Last post by mikea96
