Battery question for the RaeRe RC10 40th and DS
- Has thanked: 268 times
- Been thanked: 258 times
I’m looking for battery suggestions for my gold pan and my DS. I was thinking about putting a 2S Shorty battery with 5 mm bullets in the DS and RC 10 Buggy but I’m not sure If the brushed 1060 speed control can handle a 130 C battery. Is the discharge rate that important to take into consideration for the 1060 speed control? Is there any kind of thread or file with battery explanations with C ratings, Cell count, etc.?
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Battery question for the RaeRe RC10 40th and DS
2s is your voltage basically, a 2s is 7.4v (rated, 8.4 or so fully charged). The C rating is how fast it can discharge. Not really a consideration for the speed control. It's a consideration for the motor choice. Think of it as larger fuel line- if you are running an engine that doesn't need all that fuel it's not a limiting factor. The mah rating is going to be your run time, the bigger the number the more runtime you get. Think of that like a bigger fuel tank. The motor effects that of course but in general a 5000 will have considerably more run time than a 3000. I will say a brushed motor doesn't necessarily like running for 15 minutes at a time, so a lower mah battery would probably be my pick. If you were running brushless then it's a different story.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
The battery doesn't force power through the esc, the esc regulates the power. The motor and esc will take what they want.
A battery CAPABLE of discharging faster than the power requirement shouldn't cause any issue. To a certain point, the esc might function better. 1060's are known for going into limp mode with some batteries, with capacitors on the battery side being the solution.
Do you have examples of the capacitors?juicedcoupe wrote: ↑Tue Aug 27, 2024 4:22 pm The battery doesn't force power through the esc, the esc regulates the power. The motor and esc will take what they want.
- juicedcoupe
Those getting put inline with the battery wire?
- carloco8
- Has thanked: 74 times
- Been thanked: 271 times
I think the 1060 esc can handle down to a 12 or 13 turn brushed motor with a 2s lipo. I would be more concerned with burning up a brushed motor while having the extra run time a good lipo provides unless you have good self control and limit your run time. If you want to enjoy a long run time with a brushed motor, i recommend undergearing it so it wont get sooo hot.
I have a 17 turn motor on my 40th. Stock spur and I am not sure on the pinion.carloco8 wrote: ↑Tue Aug 27, 2024 10:44 pm I think the 1060 esc can handle down to a 12 or 13 turn brushed motor with a 2s lipo. I would be more concerned with burning up a brushed motor while having the extra run time a good lipo provides unless you have good self control and limit your run time. If you want to enjoy a long run time with a brushed motor, i recommend undergearing it so it wont get sooo hot.
- juicedcoupe
Yes.
I have never personally had a 1060 go into limp mode but it appears to be common enough.
I don't know the specific situations that caused it either. It could be people paring up the wrong motor for their combination or simply being over geared.
- Regular Member
For your Goldpan and DS, I'd recommend sticking with a lower discharge rate battery, around 40-50C. This will be gentler on the older electronics and provide ample power for both vehicles. A 2S LiPo battery with 5mm bullets is a good choice.
These are ReRe’s. New electronics. My old RC10’s are all nicad and or nimh.MikeRobert wrote: ↑Wed Aug 28, 2024 5:39 am For your Goldpan and DS, I'd recommend sticking with a lower discharge rate battery, around 40-50C. This will be gentler on the older electronics and provide ample power for both vehicles. A 2S LiPo battery with 5mm bullets is a good choice.
I think I will just go with this one. 2s lipo shorty with a t plug.
https://www.gallimods.com/shop/Batteries/p/74V-3000mAh-30C-Shorty-wT-Style-x48669247.htm
- 500 Replies
- 43317 Views
Last post by Stevothehoe
- 105 Replies
- 16962 Views
Last post by dsmith
- 1814 Views
Last post by Frankentruck
- 26 Replies
- 5955 Views
Last post by EmptyHand
- 1614 Views
Last post by Lgibjones
- 29 Replies
- 4112 Views
Last post by azone
- 147 Views
Last post by Dangeruss
- 1529 Views
Last post by juicedcoupe
