Can anyone ID this motor?
- Has thanked: 17 times
- Been thanked: 28 times
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Re: Can anyone ID this motor?
It is a Team Orion/Peak (TOP). I have several, with different color heatsinks. Lots of different labels.
Oh TOP is the model not the orientation?
Opened it up and its not a single like I thought, its double wound. Maybe 16 turns? Idk. Commutator looks very worn.
- juicedcoupe
Did you pull the armature out? Mine were all clearly marked.
I pulled the rotor out and its is marked “12T” which I guess is 12 turn. (I was way off lol). A 12 turn is a pretty hot motor. Lowest I ran back in the day was a 16turn.
- juicedcoupe
Yes, it is near end of life.
It "might" survive being cut on a lathe, depending on how well the copper was cladded to it. I've seen some that could be cut until the end and others that started peeling and flaking away.
juicedcoupe wrote: ↑Sat Aug 17, 2024 2:10 pmYes, it is near end of life.
I don’t have a lathe tho.
Ok not ideal but put the rotor in a cordless drill at high speed and put a bit of 240 grit sandpaper against it.
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
Maybe polish it with a strip of 1000 grit wet/dry sandpaper.
- 1342 Views
Last post by WriteDean
- 2051 Views
Last post by uniquenamehere
- 2277 Views
Last post by MelvinsArmy
- 2336 Views
Last post by Dadio
- 3079 Views
Last post by oneyedog
- 861 Views
Last post by coxbros1
- 2162 Views
Last post by R6cowboy
- 1141 Views
Last post by treehugger
