How to build, original or with quality of life improvements
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
I have a build that sort of organically grew. I have been collecting parts for an early Edinger runner.
The chassis was anodized before I know what I was doing. The rest of the parts are mostly NIP with some Cadillac header cards.
I am still missing one pair of notched shock pistons.
I also wound up with a number of option parts that are quality of life improvement, such as the track master long diff shaft and Losi ball bearing diff tube.
The electronics are all going to be slightly newer with a Novak receiver, nesc4 and futaba s148 with a blue label and he batteries.
The body is a husting(maybe) painted striped one.
Should I build with as much nos as possible or with some of the extra?
I think this will be the only 6 gear I keep so not likely to build a second one.
How do you all decide?
Has thanked: 2604 times
Been thanked: 2977 times
Re: How to build, original or with quality of life improvements
JosephS wrote: Fri Aug 02, 2024 1:31 pm The chassis was transfixed before I know what was doing.
Big word confuse me. What happened to the chassis?
Been thanked: 3917 times
I think transfixed is how you feel after you take your car to Aamco
It feels like one of my duct tape, "There, I fixed it" moments.
JosephS
Post by JosephS »
GoMachV wrote: Fri Aug 02, 2024 3:57 pm I think transfixed is how you feel after you take your car to Aamco
Your dealings with Aamco have been better than mine.
JosephS
Post by JosephS »
Frankentruck wrote: Fri Aug 02, 2024 3:26 pm
I am not even remotely sure how autocorrect got transfixed from ::anodized::
JosephS wrote: Your dealings with Aamco have been better than mine.
At Ford we used to say Aamco stood for All Automatics Must Come Out 🤣
1911Colt
Has thanked: 1782 times
Been thanked: 859 times
Post by 1911Colt »
Aamco projecting:
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
Thankfully, we don't all drive EV's or AAMCO wouldn't even exist.
I'll let that thought sink in. :wink:
Okay, sorry, back to the Joseph's question.
I like to build with what I have at the moment, then go back and replace parts as they become available. I really don't like having boxes of parts setting around when I know I have enough to build a car.
Dangeruss
Has thanked: 425 times
Been thanked: 1408 times
Post by Dangeruss »
Autocorrect has a knack for making perfectly healthy people sound like they're having a stroke.
XLR8 makes a good point... if it's tore down in a box waiting on parts, it isn't a runner.
I'm a big proponent of envisioning what you want the end result to be, then building to meet that vision. For a shelfer, I'd go all in on a period correct restoration. For a runner, I'd lean towards sprinkling in period-ish hop ups for reliability and ease of construction/maintenance. If I was stuck, I'd ask the question, "What would make me the happiest"... and then I'd do that. 8)
JosephS
Post by JosephS »
Dangeruss wrote: Sat Aug 03, 2024 10:23 am Autocorrect has a knack for making perfectly healthy people sound like they're having a stroke.
This is good guide. I was trying to make a way to experience driving the first RC10 with hopups available, as much as I could afford.
As I started writing this up I have a bunch of changes some are 84 catalog and some not.
So the servo and receiver are futaba j plug versions of the early parts ner2x and futaba s148 vs 2s and s48
The transmitter is a magnum senior FP-3PG
I have a machined RRP cover for the bearing adapter
The shock shafts are 'Cromed' but I am using a 1.02 in the rear vs the 1.32 since these were in the earliest catalog I have.
I already have a lot of 'option' parts. Though it seems that none of them are in the drivetrain,or can be easily pulled. I think I will stick with the original parts since I went through effort to find the parts Edinger tagged packages for most of the build.
I wasn't able to source the no hex ball cups, 1 set of notched pistons, Edinger rear tires, or the no stamp chassis.
I'll just have some parts around that won't be part of any build.
Users browsing this forum: No User Avatartgfarrell and 5 guests
