what size shrink wrap for sub-c nicad cells
- Has thanked: 1243 times
- Been thanked: 639 times
What size shrink wrap reduces to the right size for sub-c cells, what about for 3 cell sticks?
Thanks in advance
Thanks in advance
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: what size shrink wrap for sub-c nicad cells
This is 85mm wide. It was honestly too wide, I would suggest 75mm wide for packs like this. or are you needing to know what size for individual sub c cells?
I'm actually looking for the per cell wrap size and not a pack. Were you using 2:1 or 3:1 for your pack wrap?LowClassCC wrote: ↑Sat Feb 24, 2024 11:55 am This is 85mm wide. It was honestly too wide, I would suggest 75mm wide for packs like this. or are you needing to know what size for individual sub c cells?
or is the 75mm the post shrink size.
- LowClassCC
The cell shrink size is 52mm long and 43mm wide. I bought this stuff years ago in bulk and have zero clue to its shrink rate.
the green pack shrink in the pic i picked up from an ebay seller.
https://www.ebay.com/itm/193796032734
here are the sizes and what they shrink too.
Width(Dia): 7mm (Ø4mm) 9mm (Ø5mm) 12mm (Ø7mm) 15mm (Ø9mm) 17mm (Ø10.8mm) 18.5mm (Ø11.5mm) 20mm (Ø12.7mm) 23mm (Ø14.5mm) 27mm (Ø16mm) 29.5mm (Ø18mm) 31mm (Ø18mm) 36mm (Ø22mm) 40mm (Ø25mm) 43mm (Ø27mm) 45mm (Ø28mm) 50mm (Ø32mm) 53mm (Ø34mm) 55mm (Ø35mm) 60mm (Ø38mm) 64mm (Ø40mm) 66mm (Ø42mm) 70mm (Ø44mm) 75mm (Ø48mm) 78mm (Ø49mm) 80mm (Ø50mm) 83mm (Ø52mm) 85mm (Ø55mm) 88mm (Ø56mm) 90mm (Ø57mm) 91mm (Ø58mm) 95mm (Ø60mm) 103mm (Ø65mm) 110mm (Ø70mm) 115mm (Ø73mm) 120mm (Ø76mm) 123mm (Ø78mm) 125mm (Ø80mm) 130mm (Ø83mm)
Thanks for the linkLowClassCC wrote: ↑Sat Feb 24, 2024 2:22 pm The cell shrink size is 52mm long and 43mm wide. I bought this stuff years ago in bulk and have zero clue to its shrink rate.
- caesar
- Has thanked: 183 times
- Been thanked: 174 times
I just got some 40mm flat size and they fit perfectly. (2 to 1) Cut them to 50mm in length per cell.
https://www.ebay.com.au/itm/266453246832?var=566257514519
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
They look nice, are those MCI decals on colored heat shrink?
- mtbkym01
- Has thanked: 190 times
- Been thanked: 274 times
What cells did you start with?caesar wrote: ↑Fri Mar 01, 2024 12:52 am I just got some 40mm flat size and they fit perfectly. (2 to 1) Cut them to 50mm in length per cell.
- caesar
There from a guy called César Velayos Enríquez on facebook. I just messaged him through there. Just colored heatshrink with decals.
Cheers
- caesar
Some old Nicads, you could use nimh cells (they are a touch longer)mtbkym01 wrote: ↑Fri Mar 08, 2024 1:55 amWhat cells did you start with?caesar wrote: ↑Fri Mar 01, 2024 12:52 am I just got some 40mm flat size and they fit perfectly. (2 to 1) Cut them to 50mm in length per cell.
- 1159 Views
Last post by LowClassCC
- 884 Views
Last post by tamiyadan
- 27 Replies
- 3623 Views
Last post by DennisM
- 857 Views
Last post by longboardnj
- 456 Views
Last post by Halgar
- 2423 Views
Last post by duckhead
- 3016 Views
Last post by reign79
- 379 Views
Last post by coxbros1
