B3 / T3 Bearing Kits?
2BornotB2
Has thanked: 9 times
Post by 2BornotB2 »
I have a T3 Sport kit that I found on a local buy/sell page, but it comes with bronze bushings.
Would a bearing kit for B2/B3 also fit? I'm reading into Fast Eddy bearings, but it doesn't appear they have a bearing kit anymore - any other suggestions?
I'm in Canada if that helps.. thanks!
Dangeruss
Has thanked: 425 times
Been thanked: 1410 times
Re: B3 / T3 Bearing Kits?
Post by Dangeruss »
Their website shows the T3 kits in stock... though if you're trying to buy from a vendor with a lower price my suggestion would be to compare the instruction manuals to be 100% sure, then buy the kit that fits your needs.
https://img2.associatedelectrics.com/pdf/cars_and_trucks/RC10B3/Team/b3_manual.pdf
https://img2.associatedelectrics.com/pdf/cars_and_trucks/RC10T3/Team/10t3_manual.pdf
Or you could compare the product listings on Fast Eddies site to see if the contents are the same between the kits.
But if you're looking for the quickest answer... yes, the bearings are the same between the two.
As a Sport, it has the 1/4" rear axles right? If so, none of the team kits are going to work since they had 3/16" axles. Probably be better off to buy them individually.
2BornotB2
Post by 2BornotB2 »
Good point about the axles, I didn't know they were sized differently. I'll have to dig deeper into the manuals and compare them.
I know I'll need front wheel bearings and for the stealth transmission at the minimum.
jcwrks
Has thanked: 171 times
Been thanked: 393 times
Post by jcwrks »
T3 Sport kit comes with a 7378 3/16" axle.
Team Associated T3 Bearing Kit
https://www.avidrc.com/flexkit/?kit=215&kitname=T3
The TX SKUNK
Return to “RC10 Truck Forum”
