Who made Ball Bearing Bellcrank Kits for the RC10?
msedsp
Post by msedsp »
Want something better than the stcok servo saver in my goldpan and was wondering who (besides associated-have had 0 luck finding any) made ball bearing bellcrank steering kits for the RC10?
Has thanked: 357 times
Been thanked: 470 times
Re: Who made Ball Bearing Bellcrank Kits for the RC10?
RPM, MIP, Houge, Hot Trick, A&L and a few more
aconsola
Post by aconsola »
losi/rps
there are several modern dirt-oval companies which still make bellcranks that are very similar to the originals.
matteo
Post by matteo »
Who else is still making them? Which dirt oval guys...need more info. :D
aconsola
Post by aconsola »
www.kippshobbies.com
(still using old-school frames for html, so no direct link)
products>chassis>kipps first one on top is what you want.
also products>chassis>putnam these are more expensive, and the standoffs are separate(I think they come in different heights?)
Standoff height is determined by placing the "hex" portion of the aluminum on the top or bottom
of the bellcrank, and the Putnam ones won't work on a older car because they have a fore/aft
hole system for ackerman & bump steer that will connect with the rc10 front bulkhead when turned
