Wheel discoloration
Has thanked: 2605 times
Been thanked: 2979 times
Wheel discoloration
My B2 buggy has some yellow 3 piece wheels that would be pretty cool if they weren't discolored in spots. Some of the places make me think it could be from rusty parts, but other places seem like they wouldn't be. Has anyone tried successfully to remove red/orange discoloration like this? Or are theses wheels destined to be dyed black as an only option?
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Re: Wheel discoloration
Post by LowClassCC »
Frankentruck wrote: Fri Dec 01, 2023 12:20 pm My B2 buggy has some yellow 3 piece wheels that would be pretty cool if they weren't discolored in spots. Some of the places make me think it could be from rusty parts, but other places seem like they wouldn't be. Has anyone tried successfully to remove red/orange discoloration like this? Or are theses wheels destined to be dyed black as an only option?
clr may remove the rust staining but it may take a while to get it out of the plastic if it can. the other stuff i would try super clean on. I wouldn't dye them. Maybe some old school wheel disc stickers to mask them?
OldSchoolGuy
Has thanked: 4 times
Been thanked: 14 times
Post by OldSchoolGuy »
Or just paint them? Quick and cheap.
Overnight CLR treatment did not help with the discoloration. It might not be from rust.
LowClassCC
Frankentruck wrote: Sat Dec 02, 2023 1:07 pm Overnight CLR treatment did not help with the discoloration. It might not be from rust.
uv staining? peroxide maybe?
TRX-1-3
Has thanked: 2066 times
Been thanked: 992 times
Post by TRX-1-3 »
Well I recently H2O2'd some white parts that had previously had some rust staining and it seemed to remove that. It was not as "extensive" as on your wheels there. But what if hydrogen peroxide is not so much of a whitener as it is a brightener? Just a thought.
works92
Has thanked: 85 times
Been thanked: 32 times
Post by works92 »
I'll suggest sand it lightly and re-dye it in yellow.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
The dark around the edges where the tire bead seats are probably from the oils in the rubber. Maybe some simple green soaking could help it. As far as the norm goes though is to send them on down the road and new ones in order. Miss the days when these were plentiful and flippers weren't so rampant...
Tried soaking in Pine Sol cleaner. It does a good job on oils but had no effect. They are inching closer to going for a dip in my vat of black dye.
Dangeruss
Has thanked: 425 times
Been thanked: 1411 times
Post by Dangeruss »
Frankentruck wrote: Thu Dec 21, 2023 8:53 am ... They are inching closer to going for a dip in my vat of black dye.
LowClassCC
Frankentruck wrote: Thu Dec 21, 2023 8:53 am Tried soaking in Pine Sol cleaner. It does a good job on oils but had no effect. They are inching closer to going for a dip in my vat of black dye.
stained yellow wheels > dyed wheels
jcwrks
Has thanked: 171 times
Been thanked: 393 times
Post by jcwrks »
LowClassCC wrote: Fri Dec 22, 2023 5:56 pm
black dyed > stained anything
The TX SKUNK
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
By chance, have you tried lighter fluid?
I use it to clean nylon spur gears. Removes the ground-in dirt and oil stains and makes them white again.
Might be worth a try.
Users browsing this forum: No User AvatarAmazon [Bot], User avatarDangeruss, No User AvatarGoogle Adsense [Bot] and 3 guests
