Can Someone Help Me With This Wide / Narrow Band Legal Stuff
- morrisey0
- Has thanked: 87 times
- Been thanked: 1852 times
So, it dawned on my that I needed a 3+ channel Tx for my Hilux, and this is being built semi-period correctly, so an AM stick radio I went looking for. I found myself a close to new Futaba Conquest FP-T4NL with (Futaba G, FP-R4F) Rx on Channel 80 75.790mhz.
Of course I am in idiot with most of this RC stuff, so all I looked at was AM and 75mhz, and thought I was golden. Now, I am realizing that the FP-T4NL was a wide band AM radio, and assuming it was not made compliant back in the day, it is illegal to use??? Now, this isn't going to get used much at all, as the truck will mostly be a shelf'r, but I like my vehicles to be able to run. So, a pack run in the driveway once and awhile will be its normal service ............... but I don't want planes falling out of the sky!
I don't have it in my hands at this point, so I can't check for silver or gold stickers or whatever. I also wasn't actually planning on using the Rx that is coming with it because the FP-R104H that I already have looks better in the rig as it matches the servos nicely.
So, how screwed am I here? Am I good to just get something going and not really worry about interference when used rarely in 2023?
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Re: Can Someone Help Me With This Wide / Narrow Band Legal Stuff
I wouldn't give it a second thought.
- morrisey0
And now I am done thinking about it. Thanks!
- Dangeruss
- Has thanked: 425 times
- Been thanked: 1408 times
That's fantastic... I can't tell if that's sarcasm or not...
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
From my recollection narrow band was just to tighten up the channels for less chance of interference between channels. From memory that was when receivers were listed as brand specific, ie Futaba, Airtronics etc.... I'm not sure if the crystals were any different but the receivers had electronic filters in them.
Regardless the FCC isn't going to come knocking on your door.
- Has thanked: 1129 times
- Been thanked: 3917 times
I remember when it was going down, the wide band stuff used different crystals (futaba for example the rx crystal was yellow on the narrow band) and I remember 91 being the cutoff, old stuff wasn't "legal" anymore even though people kept using it. I'm sure it was banned at any big race but people messing around in the street or baseball field didn't care. As mentioned, they won't be coming after you.
Here is a copy and paste from a other copy and paste found on the interwebs ...
wrote: The following extract is from the Futaba web site to clarify the issue:
How do I know if my transmitter is legal?
The easiest way to answer this is through a series of questions. If you answer YES to any of questions 1 through 6, you do not need to continue. Your radio is legal to use in the U.S. You may use a printout of this FAQ to show your club officials to avoid any confusion or concerns.
1. Is your TX on 27MHz? If so, it is legal, no matter what model or brand. ALL TXs on 27MHz are exempt from this rule. Note: Please check the actual frequency on YOUR transmitter. (For example: 72.590 is on the 72MHz band.) Many models of transmitter are produced on multiple bands, so just looking in your instructions to see what band it was produced on will probably not answer this question.
2. Is your TX either FM (PPM) or PCM or both? If so, it is legal, no matter what Futaba model it is. ALL Futaba FM and PCM transmitters met the standard.
3. If your TX is AM, does it have a label listing it as "Narrow Band", "1991" or similar? If so, it is legal because it either was legal at time of production or was upgraded to make it legal.
4. If your TX is AM, and it was manufactured on an odd numbered channel? Then it is definitely narrow band and legal. (Simply changing a crystal does not make the radio safe, narrow band, or legal.)
5. If your TX is AM, and it was manufactured on a channel below 38? Then it is definitely narrow band and legal.
6. If your radio is AM and is in the list below, it was narrow band and legal at time of production and is legal to use:
* 2NBL
* 2NCS
* 2NBR
* 2V
* 2VR
* 2CR
* 2DR
* 2PB
* 2PBKA
* 2PC
* 2PCKA
* 2PD-AM
* 4NBL
7. Is your TX on any of these frequencies: 72.080, 72.160, 72.320, 72.400, 72.960 or 75.640? If so, it is a very old 80 KHz unit and is not legal and cannot be made legal.
8. If your radio is AM and is not on the list in step 4 AND does not already have a gold sticker on it (see photo), we cannot narrow band it for you. Unfortunately, under FCC regulation, we are no longer able to narrow band these old transmitters or otherwise provide any parts, information or service for these radios as of 3/1/98.
For example, is your radio a 4NL, 6FN, 4L, 6FN, FG series AM, 2PKA, or a 5LK? These radios are not legal for use in the U.S. at this time and CANNOT be made narrow band.
- Lowgear
- Has thanked: 121 times
- Been thanked: 792 times
This topic made me remember how consumers are also supposed to register their drones with the FAA.
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
So little bit related to the topic, what is the deal with surface use only and non surface use radios? I understand that a surface use radio probably doesn't have the communication range needed for a flying RC, but if I wanted 6 channels of control capabilities for a ground vehicle, why wouldn't I use an affordable 6 channel flight radio?
- Dangeruss
Money. Surface use airwave licensing is priced differently than aerial use. It's why you're told to "turn off your device" on a plane. Nothing to do with your iPhone crashing a 747, everything to do with your carrier not having the licensing necessary for you to legally operate the phone at altitude. Also why the phones on planes are notoriously expensive.Frankentruck wrote: ↑Mon Jul 31, 2023 7:25 am So little bit related to the topic, what is the deal with surface use only and non surface use radios?
- 1556 Views
Last post by Justin33
- 2799 Views
Last post by DaveM
- 932 Views
- 529 Views
Last post by 8rad
- 1357 Views
Last post by mk-Zero
- 958 Views
Last post by scottmac74
- 33 Replies
- 5463 Views
Last post by GreenBar0n
- 967 Views
Last post by Qballll
