LRM A-3006 Diff Center Gear Differences?
- RCveteran
- Has thanked: 26 times
- Been thanked: 200 times
Never seen this before and have had a lots of them. Triangle center? I could see how it would create less friction yet still support at this common area for melting?
- ChocoTaco73
- Has thanked: 57 times
- Been thanked: 101 times
Re: LRM A-3006 Diff Center Gear Differences?
Pretty sure thats how they all were, the JRX2 manual shows square diff ball openings as as well
James - Losi fanatic
- RCveteran
Look at the big center holes. One is a triangle here, one is the round one I have only ever seen. Both of these were recently opened NIP items.
- RogueIV
- Has thanked: 2135 times
- Been thanked: 1099 times
I have never seen a triangle center hole. Was that right out of the package from Losi?
- RCveteran
Yes, right out of packages, factory sealed, same era label. Bought recently from a seller on EBAY, I purchased two, this is how they came so new to me.
Just noticed, another one here, different seller than mine. Maybe these appeared recently from some old stash. I've had countless LRM diffs at this point and many of the coveted ball bearing ones even, but never these.
https://www.ebay.com/itm/264711210108?hash=item3da204847c:g:UMYAAOSwC7NepEhX&amdata=enc%3AAQAIAAAAwOlWWo0JSx0inbjpEuzKntMZ8Gg%2BkhfoSJVHWFFRsoyYUmqOLDl%2FeqT2mpF7HaQk666MHPWsYfS2rJNR8v2p1%2Fq1AUKSvfPIhjwj9mmtpkBPREuTnNnxqnDj%2B%2Bmr9JK0SlVw07fjRguHONkrJGDCJuVBsbHJM7w7px67%2F7d2AjF2ThKywxpawcT8CrRcDdjLriMWGgvJUVn%2FZ%2B9dsQgH7R1cz35zjwgbpWWN88S2OvwSc7h0QkSh3ZTVyaA1afhifw%3D%3D%7Ctkp%3ABk9SR7qqho_0YQ
- ChocoTaco73
Oh yeah, missed that. Odd, have never seen that before
- RCveteran
I don't know. That's the fascinating part. I started tearing apart vintage Jrx's around 2008 and probably had 100 or so and countless diffs, transmissions etc. and never came across this.
I could see this as creating less friction and also allowing a nice pocket for grease. The plastic is a bit harder and lighter gray in color as well.
How we confirm how and when these came to be, that should be good entertainment for a while. Start hunting and buy them before they are $500 a piece
Better pics or both sides.
- Been thanked: 12 times
I have one, Had it for years, don't recall exactly where I got it but it was in with a bunch of other gears and parts.
I always assumed it was a one-off molding error.
The pic here is the triangle center, standard gear and ball bearing gear.
The triangle hole is too small to fit the diff side gear, It fits <3/16" shaft in the center and the diff half stub is 1/4"
Standard gear is loose fit over 1/4" shaft and bb gear is 3/8" inner diameter.
No real help on knowing the origin of the triangle center other than that more than one exists
- RogueIV
- 1445 Views
Last post by slapshot1979
- 458 Views
Last post by slow_jun
- 25 Replies
- 2540 Views
Last post by Mr. ED
- 979 Views
Last post by Inspector Gadget
- 2321 Views
Last post by microwaveguitar
- 794 Views
Last post by HS-YZ250
- 1081 Views
Last post by greene-r74
- 47 Replies
- 8812 Views
Last post by KidAgain
