spread spectrum question
- Has thanked: 169 times
- Been thanked: 150 times
are all spread spectrum recievers compatable?
i want to make an order from tower for a few things, but they arent selling nomadio stuff anymore, and i really need another reciever for my nomadio react. will a futaba 2.4ghz reciever work? i know the horizonhobby spektrum brand is compatable...
- Been thanked: 12 times
Re: spread spectrum question
Is that a recent change? I took a look at the nomadio support site and found this:Eau Rouge wrote:Spektrum = Spektrum only
Futaba FASST = Futaba only
Nomadio = all of the above
"The React works with;
Nomadio receivers all
Spektrum all so far
Airtronics FHDSS
but not Futaba"
http://support.nomadio.net/viewtopic.php?t=1872
- Eau Rouge
- Been thanked: 5 times
I've seen guys at the track using them together, but if Nomadio says no, I'd believe them over anything else. I had heard somewhere that the system that Futaba uses was a derivative of the Nomadio 2.4 technology, but I don't know that to be true.
i've been searching like crazy the past 30 or so minutes and that post from the nomadio support boards is the ONLY bit of info i found that said anything about futaba/nomadio compatability.
doug, if you happen to remember could you ask somebody whos using a nomadio with a futaba receiver whats the deal?
- Eau Rouge
Meh.
I was at a carpet track in Wisconsin when I saw guys using them together. I may not have seen or heard what I thought I saw if Nomadio says nada on the compatibility thing.
- JK Racing
- Has thanked: 129 times
- Been thanked: 242 times
Wish I would have known that before I bought the M8 and Spektrum module....Eau Rouge wrote:Nomadio = all of the above
- Has thanked: 7 times
- Been thanked: 42 times
Hey Eau Rouge, could you get back to me about the motor plate? Thanks!
Adam
Adam
that makes sense because the new futaba 4pk radio looks similar to a Nomadio style radio.I had heard somewhere that the system that Futaba uses was a derivative of the Nomadio 2.4 technology
- call-911
Has anyone used one of those Losi spektrum receivers? Have you heard any complaints? I read that they are compatible with Spektrum and are much cheaper too. How do they compare in size?
Keith C
- Erich Reichert
The Losi ones are completely compatible with Spektrum... they're actually just the original recievers (non "pro") with a different case. An interesting sidenote is that the FASST ones are not ALL compatible with all futabe 2.4ghz systems... We have a bunch of them for the 3pk FASST and then had a few of the lower FASST radio's recievers and they don't work together. I.E. you can't have both kinds of Futaba 2.4 recivers and control them with the 3PK
The losi rx does work fine with the standard spektrum stuff.call-911 wrote:Has anyone used one of those Losi spektrum receivers? Have you heard any complaints? I read that they are compatible with Spektrum and are much cheaper too. How do they compare in size?
The MSRP for the rx unit (#losb0806)is listed as 59.99 in the original mini-Slider parts list, and it was available for ~$45.
The price was a lot cheaper until a couple of months ago. On their website Horizon raised the MSRP to 109 and the MAP to 74.99, they must have realized that many folks were buying them instead of the 79.99 spektrum branded ones.
- 961 Views
Last post by Oozzee
- 29 Replies
- 1813 Views
Last post by RedScampi
- 2191 Views
Last post by biff85ta
- 1234 Views
Last post by treehugger
- 2642 Views
Last post by stingerrray
- 27 Replies
- 2458 Views
Last post by MelvinsArmy
- 848 Views
Last post by Dr. Robotnik
- 1918 Views
Last post by WillyThickfoot
