Difference between XXX4 and XXX-S chassis
Forum rules
- Has thanked: 17 times
- Been thanked: 13 times
I am curious what the main difference between the two chassis's is? I know the wheel base is different but like the XX4 (extra 1/2" that can be noticed when checking between the servo mount and reciever mount or cuts between the cell punchouts ) there is going to be some difference that can be used to I.D a XXX4 chassis. At first I thought the slightly wider cell opening on a couple cells in the chassis was it but noticed some XXX-S models have the same thing. Any help is appreciated.
- RogueIV
- Has thanked: 2139 times
- Been thanked: 1100 times
Re: Difference between XXX4 and XXX-S chassis
I have both cars. As far as the Chassis itself goes the only real difference is 13mm in length. All this length is aft of the rear pivot mounts. Pictures for reference, note that they aren't perfect.
Thing of note with old Losi vehicles that I've found while making custom parts, despite the fact that they use imperial hardware, shafts and bearings almost all measurements on the cars are measured in metric, usually within 0.5mm.
Thats awesome man! Thank you! This answers my question exactly.
- 1247 Views
Last post by RogueIV
- 747 Views
Last post by CamplinP
- 494 Views
Last post by Dadio
- 1194 Views
Last post by DennisM
- 3890 Views
Last post by emreyzc53
- 1463 Views
Last post by photogRC
- 24 Replies
- 6540 Views
- 2121 Views
Last post by radugns
