Vintage Tekin receiver...is AM or FM?
GeneralZod
Has thanked: 150 times
Been thanked: 162 times
Post by GeneralZod »
Can anyone can identify this old Tekin? Not much labeling on this one.
Has thanked: 2605 times
Been thanked: 2979 times
Re: Vintage Tekin receiver...is AM or FM?
It looks like a 27mhz AM, earlier that the TERX models.
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
Looks cool! Black antenna wire is typically AM 27mhz, right?
-Brad
Has thanked: 269 times
Been thanked: 2094 times
I have one just like it, AM.
GeneralZod
juicedcoupe wrote: Wed Jul 06, 2022 7:27 pm I have one just like it, AM.
27Mhz? I don't think I have any transmitters that can wake this one up ..... Wonder if my Magnum JR would work if I had matching set of 27Mhz crystals. Currently, the Jr is on 75Mhz. I think I may have to start looking for a 27Mhz radio.
Mine is 27mhz, but they were available in multiple frequencies.
It is a Micro Pro, which is older than the TERX.
Here is mine, alongside a Tekin Mospower esc.
GeneralZod
juicedcoupe wrote: Wed Jul 06, 2022 10:05 pm Mine is 27mhz, but they were available in multiple frequencies.
Oh, yours in bag has a red wire and 27Mhz. Interesting....now I wonder if the black wire on mine has any significance. I guess I could pop in a 75Mhz crystal and see what happens. You don't think it would hurt anything if I tried? If it were 75Mhz, do they typically use a green wire?
I have a newer TERX 75 that has a green wire, which follows the Novak trend. However, I believe that the guy at Tekin was known for kinda doing whatever.
I can't see having the wrong band crystal installed causing any problems. If wrong, it shouldn't communicate.
GeneralZod
OK, I'll give it a try. Thanks for your help everyone!
GeneralZod wrote: Wed Jul 06, 2022 9:38 pm I think I may have to start looking for a 27Mhz radio.
If it is 27mhz, that kinda makes things easy.
Pretty much all 27mhz (AM) hobby grade stuff works together. You can mix and match transmitters, receivers, and crystals.
In addition to the six common channels, there are six more "half channels". You can sometimes find these crystals with X Mod stuff. I recently picked up a near complete set.
Just don't buy a X Mod transmitter. The crystals work but the transmitters are different.
