JRX2 Parts on Shapeways
- Has thanked: 184 times
- Been thanked: 63 times
Hi All,
Going to rebuild/restore a JRX2 (was inspired by the Mini that was just released). Has anyone used Shapeways? How are their 3D printed parts?
Thanks a bunch,
Dean
Thanks a bunch,
Dean
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Re: JRX2 Parts on Shapeways
I have several. The fit is only as good as the designer made them. Some fit like originals, others require some fitting.
- Has thanked: 2759 times
- Been thanked: 2250 times
I've got a Shapeways shop myself , the plastic is on par with vintage parts for strength , not as good as modern carbon plastics , as above it really depends on the designer of the part , it works like this , I design a part and personally I home 3d print everything to be sure it's right , then I upload the CAD file to Shapeways , they put in their catalogue , the customer orders it , Shapeways print and post it and I get a comission payment . At no point do Shapeways check the part fits or does what it's intended to do , that's down to the designer .
- Has thanked: 1129 times
- Been thanked: 3919 times
A part that was made to be injection molded will rarely produce a good strong 3D print part. If you are having parts printed for shelf duty you might look at resin prints. The quality is amazing. For strong parts that can be used, you will likely find the parts made thicker and bulkier all around.
- Has thanked: 1153 times
- Been thanked: 624 times
Shapeways parts are high quality but can get expensive pretty quickly. I haven’t tried any for the Jrx2 because I have wanted to keep those cars original. There are still a lot of common Jrx2 parts out there for restorations without resorting to 3d printed parts.
-Brad
Not for long , with the 1/16 re re it's going to prompt a surge of interest in the full size car , parts are going to vanish as interest grows .BattleTrak wrote: ↑Mon May 30, 2022 7:42 pm Shapeways parts are high quality but can get expensive pretty quickly. I haven’t tried any for the Jrx2 because I have wanted to keep those cars original. There are still a lot of common Jrx2 parts out there for restorations without resorting to 3d printed parts.
Yes..you do have a good point there. It is nice being able to find parts in 3D when not available elsewhere.
-Brad
Thanks, everyone. It’s gonna be a shelf car. The item I’m considering are original type shock collars and the original battery box.
Those are probably the two hardest parts to find originaI. I won’t mention how much I paid for a NIP battery box.. It’s a beautiful buggy when done though!
-Brad
Those are fairly simple designs that would be hard to screw up too far , I'd probably trust they would work .
That looks amazing!BattleTrak wrote: ↑Tue May 31, 2022 8:32 amThose are probably the two hardest parts to find originaI. I won’t mention how much I paid for a NIP battery box.. It’s a beautiful buggy when done though!
[img] https://i.postimg.cc/fL3W15D5/D32-FB547-B56-D-4-A90-B759-5-DD8-DC176-B7-A.jpg[/img
- 1331 Views
Last post by mikea96
- 19 Replies
- 5173 Views
- 2112 Views
Last post by xxx2fast4u
- 916 Views
Last post by bearrickster
- 1951 Views
Last post by aconsola
- 955 Views
Last post by RCveteran
- 1105 Views
Last post by mk-Zero
- 990 Views
