CC/12LS 4-2
- hav3rchuck
- Regular Member
- Has thanked: 9 times
Re: CC/12LS 4-2
That is just cherry.
I always wanted an rc12 as a kid. I don't know of any indoor tracks in my area that I could justify getting one either. I will just drool at everybody's awesome cars on here.
Have fun with it!!!
Have fun with it!!!
- ELF-BMX
- Has thanked: 31 times
- Been thanked: 50 times
Re: CC/12LS 4-2
Thank you! I only have 1 carpet track 1 hour away so it tuff sometimes but I usually just go to the local highschool running track or very smooth parking lot with cones.hav3rchuck wrote: ↑Thu Feb 17, 2022 3:00 pm That is just cherry.
Have fun with it!!!
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
Re: CC/12LS 4-2
Do you do anything to protect the underside when running outside? The chassis gets scuffed up pretty easily with such low ground clear.
- Has thanked: 8 times
- Been thanked: 19 times
- ELF-BMX
Re: CC/12LS 4-2
Theres no foam on wheels, thats why it looks do low but even with foams im only sitting 1/4” higher. This us just for shelf BUT if i did run it I would definitely cover the bottom with some tough tape.Frankentruck wrote: ↑Fri Feb 18, 2022 10:31 am Do you do anything to protect the underside when running outside? The chassis gets scuffed up pretty easily with such low ground clear.
- ELF-BMX
Re: CC/12LS 4-2
The axle is just a typical rc12l3 axle, its not era correct as the axle came out after this model but i want to use the yokomo wheels badfolkdeath95 wrote: ↑Wed Apr 27, 2022 3:42 pm Beautiful car!![]()
What's the 3 bolt rear axle you're using?
Re: CC/12LS 4-2
Thanks.ELF-BMX wrote: ↑Sat Jun 04, 2022 6:05 pmThe axle is just a typical rc12l3 axle, its not era correct as the axle came out after this model but i want to use the yokomo wheels badfolkdeath95 wrote: ↑Wed Apr 27, 2022 3:42 pm Beautiful car!![]()
What's the 3 bolt rear axle you're using?.
I like your threaded front axles, too. Much clever than using the E-clips, imho.
