Surprised at how nice the 6 gear is
- Has thanked: 1243 times
- Been thanked: 639 times
I just put together my second rc10 6 gear. My first was 3 decades ago.
I wanted to go original as I could. If money wasn’t an object I would have had an original MSC, bushings and the full body kit with driver and stickers, but all of that would have really increased the cost of the build.
It’s really a nice car to drive even with the mechanical
speed controller.
It still needs bearing for the front wheels, shocks, e-clips ,nose braces and A stamp wing tubes .
After my first project I think I am going to build and get things running ASAP before i go out and make multiple part orders.
What is the length supposed to be for A stamp bulkhead wing tubes?
It’s way longer than the team car tubes for sure.
Also the j-concepts wheels I got came yellowed? How should those be whitened?
speed controller.
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Re: Surprised at how nice the 6 gear is
Just so happens I got one from a current rebuild.
Chuck
Chuck
I forgot about having throttle or steering when the battery runs down.
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Something to think about.
The same length wing tubes don't fit some bodies as well as others. I always cut them to whatever length fits the body best.
I see that you don't have nose tubes either. I prefer to make them shorter than the originals, leaving extra room around the servo and bellcranks.
I use K&S 83060 tubing to make mine (tapping it can be frustrating).
If you decide to buy the JConcepts nose and wing tubes, be aware that the wing tubes are the short versions and they aren't drilled through. They are tapped at each end (4-40) but are fairly easy to drill for the wire to pass through. I actually used a set with a early bulkhead by using 4-40 cap screws on the bottom to adjust the length and then glued them in place (required).
Thats weird about the wheel color. I have several sets of JConcepts wheel (including those) and all are much whiter than the original AE nylon parts and haven't yellowed any.
How are your cars stored? Possibly somewhere that could expose them to the elements (garage or shed, maybe?).
They might clean up with a good scrubbing. Dish soap and a stiff toothbrush will do more than most think.
They came out of the package like that. I gotta try cleaning them upjuicedcoupe wrote: ↑Mon Sep 06, 2021 11:36 pm Thats weird about the wheel color. I have several sets of JConcepts wheel (including those) and all are much whiter than the original AE nylon parts and haven't yellowed any.
How I store my cars is going to be another topic. They are stored outside unprotected (under shade) in desert conditions. I've taken to storing my unused parts in a bucket of water. It looses about a 3/4 a gallon a week to evaporation. I've had to throw some bleach drop in the water to prevent alage.
I was thinking of getting tubing from McMaster since I am building up an order.
3/16" OD and .09" ID https://www.mcmaster.com/catalog/127/190
I keep hesitating on the order because I am not sure it's worth $17 for me to have snap ring pliers for the 12 snap rings on 2 gold pans.
- juicedcoupe
For the outdrives, my regular small ones fit. They were from a cheap set (Harbor Freight, or similar).
For the shocks, I modified some small forceps to fit. They work but I usually find myself using picks instead.
So that run ended abruptly
I cleaned the motor in water it was about 2x as fast as it was before. That did not help.
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
I've just recently heard about cleaning brushed motors in water. Is that actually, purposely putting a running motor into water?
I tried it and I can't recommend it. The motor was slow but smooth before. Now it sounds like arcing popcorn but is super fast.Frankentruck wrote: ↑Tue Sep 28, 2021 9:45 pm I've just recently heard about cleaning brushed motors in water. Is that actually, purposely putting a running motor into water?
though the popcorn sound could be something else built wrong as well. Somehow I thought my experience with stealth based Rc10's would transfer but nope. It's a totally different beast.
- Has thanked: 1129 times
- Been thanked: 3917 times
This was how we would break in motors. Low voltage (a couple cells) and dip the motor in water while running a few times. It would quickly break in the brushes and you were good to go. Not for cleaning at all. Only motor spray in my motors.Frankentruck wrote: ↑Tue Sep 28, 2021 9:45 pm I've just recently heard about cleaning brushed motors in water. Is that actually, purposely putting a running motor into water?
- juicedcoupe
Just got a set of these. They are sooo much better than what I was using.juicedcoupe wrote: ↑Tue Sep 07, 2021 5:59 pmFor the outdrives, my regular small ones fit. They were from a cheap set (Harbor Freight, or similar).
https://www.amazon.com/4411J0-Internal-Straight-Retaining-5-75-Inch/dp/B001E5X9YY
I rebuilt a set of bottom load shocks a couple days ago. They were in rough shape but the pliers still removed the clips with ease.
For absolutely no good reason I feel just a little bad for opening NIP parts.
- juicedcoupe
They are still old, so I'd soak them to rehydrate.
I'd soaked the original parts for a few days before assembly. I am beginning to wonder if that wasn't enough.
I went and boiled/simmered them for 20 minutes; I hope that is enough.
- 2014 Views
Last post by discgolfer72
- 1161 Views
Last post by isobarik
- 1836 Views
Last post by SRTracer121
- 661 Views
Last post by LowClassCC
- 2518 Views
Last post by Worldsman
- 21 Replies
- 3033 Views
Last post by RCveteran
- 1844 Views
Last post by drbelleville
- 43 Replies
- 3696 Views
Last post by Halgar
