not a bad haul picked up some nice custom current gear
Forum rules
- discgolfer72
- Has thanked: 21 times
- Been thanked: 36 times
traded off some of my Tamiya stuff that I never run , and don't ever plan on
gave up a frog roller, hornet roller , rtr Nissan king cab , rtr blackfoot , and a few other random oldies
and got these ,+ a big pile of parts and custom cut carbon chassis that fit the losi 22 , several shorty lipo , and a few esc sets
the tmax was nitro and had the motor but im already in the process of converting it to electric (had the gear box on hand) just need the driveshaft's to connect the new gearbox
- discgolfer72
Re: not a bad haul picked up some nice custom current gear
first truck all done
going to be a hell of a sleeper as soon as I get new tires
- discgolfer72
well guess ill keep talking to myself lol
next truck is underway
hit a bit of a snag
hpi flux 1/8 brushless motor uses a 5mm shaft with a odd pitch on the pinion
soo had to order a new pinion
but good news is esc and motor mounted up without needing any help .
now just need to whip up a 3d print for the battery holder , and shifter servo(and guess I should make something to block the second motor hole so no dirt gets in)
hit a bit of a snag
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
Matt
- KidAgain
- Business Member
- Has thanked: 513 times
- Been thanked: 431 times
Were here bud just lurking around
- discgolfer72
- discgolfer72
did get the tmaxx conversion finished up its pretty dam crazy , wheelies at half throttle
had to go out and pick up a wheelie bar yesterday
not bad for a crappy nitro truck with a short wheel base
had to dial the esc back to lowest punch setting and enable a 10% drag brake (would front flip if used the brakes )
- 1107 Views
Last post by a01butal
- 1342 Views
Last post by JosephS
- 1879 Views
Last post by Tadracket
- 785 Views
Last post by SteveK
- 1166 Views
Last post by ZED32
- 902 Views
Last post by Y'ernat Al
- 847 Views
- 1307 Views
