Paint stripping
Crawlernerd
Has thanked: 21 times
Paint stripping
Post by Crawlernerd »
Hey guys (and gals) Any tips on removing paint from the white nylon plastic used on the RC10. I am getting one someone has painted all the suspension and wheels. It looks like a nightmare but going to give it a shot. Thanks in advance.
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Re: Paint stripping
Post by JosephS »
Crawlernerd wrote: Sun Jul 25, 2021 3:30 pm Hey guys (and gals) Any tips on removing paint from the white nylon plastic used on the RC10. I am getting one someone has painted all the suspension and wheels. It looks like a nightmare but going to give it a shot. Thanks in advance.
Nylon is a pretty strong plastic. I have found that at least with limited exposure acetone does not change nylon.
Now I typically leave exposure as short as I can and actively work with a soft bristle brush. I was able to take some spray paint off without fuss.
Has thanked: 269 times
Been thanked: 2094 times
Re: Paint stripping
Citristrip works as well.
I normally use Citristrip to remove the bulk of it, then soak in acetone to remove tougher spots.
Worldsman
Has thanked: 5 times
Re: Paint stripping
Post by Worldsman »
Hi,
I use Brake Fluid dot4 to remove paint from plastic parts.
Soak the parts 2 or 3 days in the Brake Fluid, then use a toothbrush to remove the paint.
After that hold it under Walter and clean it.
I had ever good results. And Brake Fluid does No damage to Plastik parts.
Best regards.
