paint stripping
- Hcp22
- Has thanked: 33 times
- Been thanked: 22 times
Re: paint stripping
You can use fuel for RC-nitro engines’; it takes a wild, so you have to be patience!
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Re: paint stripping
Nitro fuel works very good on most paints. My method is to use a paintbrush dipped in fuel to gently scrub off the paint
- shodog
Re: paint stripping
I only use nitro fuel. Oven cleaner and brake fluid ( which btw work great for hard plastic bodies) will damage lexan.TZona wrote:thanks, any damage to the lexan? anything household. i have no nitro's
Re: paint stripping
what about percents and car vs. heli/plane? i'll ask my friend he did nitro helis but i think he went all lipo
- Regular Member
Re: paint stripping
dot 4 brake fluid works well, try to stick to rubbing with paper towels, i stripped an f1 body down to bare lexan and the toothbrush i used left some scratches in the lexan, covered up with white paint though.
Re: paint stripping
I haven't found anything that will touch silver paint in terms of gasoline and/or brake fluid. I've tried gasoline and brake fluid on factory silver paint on a Duratrax RTR and an older Dahm's Buggsy body that I would love to rehab, but the paint won't budge.
I think in future I'll back my paintwork with white instead, because you never know when or what you'll want to repaint.
Re: paint stripping
ya watched a vid on utube dot 4 worked well. who ever invents stripper for clear bodies is going to be a rich rich boy lol!
- SFC K
- Has thanked: 47 times
- Been thanked: 9 times
Re: paint stripping
Testers makes a paint removal now for lexan, called Easy Lift Off. I have not tried it yet but RC Car Action Magazines had mentioned this in there "How to Bomb Proof Your Body" FEB 2011 issue. Apparently it will remove lacquer paint from lexan bodies without so much as fogging it up. It's 100% safe on polycarbonite bodies.
http://www.testors.com/product/69364/F542143/_/ELO_Paint_%26_Decal_Remove_8oz
Jeff
- SFC K
Re: paint stripping
1st time I had heard of it when i read the article. I plan on trying it out on an a 57' chevy body that I want to repaint.Lowgear wrote:That stuff isn't really new and has been mentioned on here a number of times in the past but I'm really curious to see how it works.
Jeff
Re: paint stripping
Definitely.
I need to know if this stuff works ... I will suddenly have a bunch of painting projects to do if I can save some of these bodies.
I have at least 2 Dahm's bodies to rescue, and an original TRX-1 body, too.
Let us know how it works, and please note what brand and color of paint you attempted to remove.
I'm really regretting backing just about every painting project ever with some kind of silver lacquer ...
Re: paint stripping
DOT4 break fluid. Make sure it is DOT4 not DOT3. Check the youtube video: http://www.youtube.com/watch?v=085nJyj4TBM
eBay ID: Nsr250_sp_repsol
- 1217 Views
Last post by karnivool
- 1264 Views
Last post by Worldsman
- 1794 Views
Last post by Dr. Robotnik
- 972 Views
Last post by bearrickster
- 2316 Views
Last post by mAdMan
- 887 Views
Last post by mrhemi1971
- 1599 Views
Last post by JK Racing
- 912 Views
Last post by rctenracer
