My ultima pro
Medved
Been thanked: 7 times
My ultima pro
Post by Medved »
I present to you my original ultima pro.
This was bought off ebay last year as birthday present to myself to give me a large dose of nostalgia. I raced one as a kid back in 91-94 when everybody else had Schumacher cougars and rc10s.
I had to replace the front bulkhead and somewhere along the road a previous owner decided to cut down the top deck.
It now has a a shorty lipo conversion, savox low profile servo, hobbywing 10.5t motor and a turnigy trackstar 80a esc. Oh and jcracing 2.2 wheels.
I run it with an 18t pinion and 20‰ turbo on the esc and it is rapid. I run it as original as I can get it.
Have to say it is a joy to drive
Ultima
Ultima
Ultima
Ultima
mikea96
Has thanked: 659 times
Been thanked: 878 times
Re: My ultima pro
Post by mikea96 »
Looks good! Those wheels really make it look nice.
threesheds
Has thanked: 59 times
Been thanked: 71 times
Re: My ultima pro
Post by threesheds »
Looks like a lot of "toe out" on front wheels, is that how they are set up or just the photo?
Medved
Re: My ultima pro
Post by Medved »
I think it's just the photo. I run them pretty much level with as close to 0 degrees as I can.
Has thanked: 2605 times
Been thanked: 2979 times
Re: My ultima pro
Do you run a hardened final pinion in the gearbox? Back in the day, my Turbo Optima would eat up the OEM aluminum final pinion, and then that would chew up the mating gear. A steel replacement from Thorp eliminated the problem. I do see the Thorp 4738 final pinion on eBay. It's overpriced, but might be worth considering.
Re: My ultima pro
Medved wrote: Thu Jul 15, 2021 3:01 pm I think it's just the photo. I run them pretty much level with as close to 0 degrees as I can.
I agree...cellphone pics these days really seem to exaggerate toe angles, especially with top-down pics. Kind of a fish-bowl effect when taking close-up pics.
Frankentruck wrote: Thu Jul 15, 2021 3:16 pm Do you run a hardened final pinion in the gearbox? Back in the day, my Turbo Optima would eat up the OEM aluminum final pinion, and then that would chew up the mating gear. A steel replacement from Thorp eliminated the problem. I do see the Thorp 4738 final pinion on eBay. It's overpriced, but might be worth considering.
Yep, agreed. Definitely a necessary upgrade, if it's gonna be a runner. I believe someone here sourced a generic one online somewhere that had the correct pitch and dimensions, but hope someone else can help out and link it.
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Re: My ultima pro
Post by XLR8 »
Wow, what a nice ride you have there! I need to order myself a set of those wheels - they look great on your car.
"Have to say it is a joy to drive." I couldn't agree more.
I've been running the wheels off mine the last few days (detail here https://www.rc10talk.com/viewtopic.php?f=30&t=44380).
I've stumbled upon what seems to be the perfect motor and gearing combination for my little loose-dirt backyard track and the car is just amazing to drive. I love it!
By the way, but have you seen this?
Could this be the most costly Ultima ever built?? Anyway, I think it's pretty amazing to see Joel drive this car.
tagger
Re: My ultima pro
Post by tagger »
Nice ride.
I raced one back then too. I had a Thorp gear set and a Trinity or Composite Craft chassis and a few other bits that made it competitive and reliable. Then Losi was the flavour or the month so I started racing a Jrx2 - which I still have.
I wish I had kept the ultima too...
SnowTheProto
Re: My ultima pro
Post by SnowTheProto »
I have an Ultima Pro as well how did you get/make that under tray as I need one to stop all the dust and things getting inside it. also did you change the gears out with that new motor as I am worried if I put more power into it the gears could strip on mine. it runs well but there is a lot of steering slop may need help with that too.Image Image
Dadio
Has thanked: 2759 times
Been thanked: 2250 times
Re: My ultima pro
Post by Dadio »
SnowTheProto wrote: Sat Jun 24, 2023 11:54 am I have an Ultima Pro as well how did you get/make that under tray as I need one to stop all the dust and things getting inside it. also did you change the gears out with that new motor as I am worried if I put more power into it the gears could strip on mine. it runs well but there is a lot of steering slop may need help with that too.Image Image
Oooh that's dirty :wink:
SnowTheProto
Re: My ultima pro
I know that’s an oldish photo heres a better image of it right now and I’m really proud to have kept it functional. Removing the rear sway bar made it run better for me.
Delorean
Has thanked: 17 times
Been thanked: 14 times
Re: My ultima pro
Post by Delorean »
Hey mate
What bits did you use to do the shorty conversion mate? It looks great. I just picked up a pro with the same alloy chassis but was puzzled as to what holder I could mount but it looked difficult with all those slots for the saddle pack
Cheers
Mikey
Medved wrote: Tue Jul 13, 2021 11:30 am I present to you my original ultima pro.
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarTbot [Bot] and 5 guests
