McMaster-Carr order substitutions for assocaited parts
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
hey for all of you who have done this before can you help me see if I have the right substations for this order in McMaster Carr
The one I am least sure of is the carbon steel shim in place of a diff drive ring.
I am also trying to figure out the right spacers to go between the o-rings in the shocks.
As well, I have been seeing x-rings replaced orings in the modern shocks? Is there a better performing gasket I can be using in these shocks?
Are there other commonly needed rebuild items that I am missing?
Team Associated Diff Drive Rings 2.25:1 Diff (ASC6579)
https://www.mcmaster.com/90482A432/
1074-1095 Spring Steel Ring Shim
0.02" Thick, 1/2" ID
90482A432
(previous this linked to a ring that was far too thin.)
here is the thread that discusses member experience with these
https://www.rc10talk.com/viewtopic.php?t=46849&start=15
Diff Balls 3/32 asc 6581
Tight-Tolerance Hardened 440C Stainless Steel Ball
3/32" Diameter
9642K25
asc5407 red shock gasket
High-Temperature Silicone O-Ring
1/16 Fractional Width, Dash Number 006
1283N16
E-clip ASC 6299
Side-Mount External Retaining Rings
for 1/8" OD, Black-Phosphate 1060-1090 Spring Steel
97431A240
Shock cap O-Ring 6469
Oil-Resistant Buna-N O-Ring
1 mm Wide, 10 mm ID
9262K104
Shock rebuild internal spacers
Nylon Unthreaded Spacers
3/16" OD, 1/8" Long, Black
90176A102
Shock rebuild internal spacers Aluminum Edinger
Aluminum Unthreaded Spacers
3/16" OD, 1/8" Long
92510A688
Retainers for gold mount shocks
Internal Retaining Ring
for 5/16" ID, Black-Phosphate 1060-1090 Spring Steel
99142A320
Retainer for 6gear bearings
for 3/8" ID, Black-Phosphate 1060-1090 Spring Steel
99142A330
https://www.mcmaster.com/9262K104
Locknuts, 8-32, Low Profile, steel (asc6953)
Low-Strength Steel Thin Nylon-Insert Locknut
Zinc-Plated, 8-32 Thread Size
https://www.mcmaster.com/90633A009/
Has thanked: 268 times
Been thanked: 2094 times
Re: McMaster-Carr order substitutions for assocaited parts
I don't ever have a problem finding similar replacement parts.
The diff rings are still relatively available. And unless the diff is just trashed, I normally don't replace them. Usually flipping and/or wet sanding them is sufficient.
And finding appropriate sized diff balls isn't an issue either. They are still available by several companies.
All of the clips and o rings are also readily available. Usually a quick search will give you a usable option for many things.
Sorry I can't be more specific about the McMaster Carr item, I never order from them. To me, they are usually over priced and their shipping rates suck.
McMaster far outweighs paying 4 bucks for 10 orings when you can get 100 for 3 bucks. Same for most of those parts. When you have 10 cars to build buying small packets adds up really quickly. I've done the math plenty of times. Maybe your location causes problems with shipping and pricing? I get parts the next day and usually like 5-6 bucks.
However I do agree that diff balls and diff rings are better purchased from associated as they are custom/cost effective. The balls are carbide and trying to buy them elsewhere is more expensive.
Just for reference, I just bought a 100 pack of -006 silicone 70A o rings on Amazon for less than $2 shipped. I prefer 50A but they can be hard to find sometimes.
The Traxxas ultra shock rebuild kit is a good source for several items. At $2.50, it's a steal.
The 1/8 e clips are a few dollars for ten of them, from Custom Works. The price is cheap enough and I know that they fit good.
I don't live in an obscure area or anything. But any time I put a M-C order together, the shipping is always insane. I don't know what the deal is. I have the same problem with Rock Auto, insane shipping.
Hmm man that sucks. But yeah Amazon can get you bulk stuff too. And the Traxxas subs are also a great idea.
JosephS
Post by JosephS »
jwscab wrote: Thu Jun 17, 2021 8:24 pm McMaster far outweighs paying 4 bucks for 10 orings when you can get 100 for 3 bucks. Same for most of those parts. When you have 10 cars to build buying small packets adds up really quickly. I've done the math plenty of times. Maybe your location causes problems with shipping and pricing? I get parts the next day and usually like 5-6 bucks.
This was actually kicked off because I was having trouble sourcing rings as they are back ordered at both amain and tower. They are on amazon for $6-7 a pair. Is there another place that I should be looking?
For me the shipping on the list I put up is $6.5 from MC so that isn't much of an issue. It seems like that's not really a recommended path.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
+1 on the AE diff balls, as Joe said they are carbide and don't need replacing all that often. Stainless steel is actually quite soft so I would avoid that.
Most of the time a grainy diff is caused by the thrust bearing, so if you can find those in bulk you'll be better off.
KidAgain
Business Member
Has thanked: 513 times
Been thanked: 431 times
Post by KidAgain »
juicedcoupe wrote: Thu Jun 17, 2021 8:46 pm Just for reference, I just bought a 100 pack of -006 silicone 70A o rings on Amazon for less than $2 shipped. I prefer 50A but they can be hard to find sometimes.
whats usable from the Traxxas shock rebuild kit?
KidAgain wrote: Fri Jun 18, 2021 8:51 am whats usable from the Traxxas shock rebuild kit?
Depending on whether you have top or bottom load shocks (I have both), everything except the diaphragm.
The spacers do need to be reamed for the 1/8" shafts, as they are slightly larger than a 3mm shaft. Alternatively, current 3mm shafts can be used if you can find the correct length.
The larger spacer, end piece, and snap rings fit bottom loaders. The smaller spacer is correct for top loaders. The smaller spacer and end piece are made from a more pliable material, instead of hard plastic.
The o rings are similar to currently available x ring designs. Some people don't like them but I've had good results from them.
The diaphragm also fits small Tamiya CVA's (green seal) and Duratrax gold shocks for sure. Probably fits Kyosho golds as well. However, I do think the green Tamiya seals are better quality (but cost more and can be hard to find).
oozee
Has thanked: 6 times
Post by oozee »
Thank you all for very useful information.
I am ordering these o-rings for shock rebuild. I have not verified the fit.
https://www.theoringstore.com/store/index.php?main_page=product_info&products_id=1770 1mm CS X 10mm ID (NBR) Buna-N 70 Duro Metric O-Ring - top cap o-rings
https://www.theoringstore.com/store/index.php?main_page=product_info&products_id=758 AS568-006 B50 (NBR) Buna-N Nitrile 50 Duro O-Ring - internal bottom o-rings
https://www.theoringstore.com/store/index.php?main_page=product_info&products_id=1709 1mm CS X 12mm ID (NBR) Buna-N 70 Duro Metric O-Ring - spring adjustment nut o-ring
https://www.theoringstore.com/store/index.php?main_page=product_info&products_id=24046 Super Lube® 21010 Synthetic Grease 1/2oz Tube Carded - o-ring lubricant
I hope it helps others.
