Dynotech klien arms
General info, Q&A.
Medved
Been thanked: 7 times
Dynotech klien arms
Post by Medved »
Hi all,
Question about the klien Arms that are commonly used as rpm replacements.
Do they work with. 71 shocks and the standard rc10cw shock tower?
I have a truck nose and some spare. 71 shocks, but don't have the longer travel versions, would this work?
Also with the rears, can you just run them with the regular chassis width and rear arm mounts? Would this affect the dogbone length?
Thanks
Has thanked: 269 times
Been thanked: 2094 times
Re: Dynotech klien arms
The RPM tower has a set of lower holes for shorter shocks. But I think that the Quadra tower is specifically for 0.71 shocks.
https://www.rc10talk.com/viewtopic.php?f=38&t=10403
Tons of information here.
If you want to use standard length dogbones, the arms would have to be moved in, like the RPM Worlds setup.
If you use them with standard mounts, you will need longer axles.
