Lunsford Punisher Turnbuckles RC10T
Rscot808
Post by Rscot808 »
Just picked up an RC10T that I’ll be rebuilding and hopefully documenting on this sight.
I’m looking for Lunsford Punisher Turnbuckles / tie rods. I wasn’t able to find a kit for the RC10T. Anyone know how to piece one togeather? I see T4 ones but read they are too long. Thanks!
Been thanked: 3919 times
Re: Lunsford Punisher Turnbuckles RC10T
Just call Barb at Lunsford, they have the old style and the punishers both.
Rscot808
Post by Rscot808 »
GoMachV wrote: Tue Mar 09, 2021 1:16 pm Just call Barb at Lunsford, they have the old style and the punishers both.
Awesome thanks!
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
I think the 10T and T2 use the same 6 x 2.62" turnbuckles
Has thanked: 269 times
Been thanked: 2094 times
RC10th wrote: Tue Mar 09, 2021 10:11 pm I think the 10T and T2 use the same 6 x 2.62" turnbuckles
From what I've seen, those really only work right with the small AE ball cups. At least, the AE turnbuckles don't have enough thread to allow decent adjustment with larger ball cups.
I just did a 10T with 6 x 62mm turnbuckles and RPM standard ball cups. I have another with 50mm turnbuckles, with one standard and one long RPM ball cup.
Rscot808
Post by Rscot808 »
juicedcoupe wrote: Tue Mar 09, 2021 11:22 pm
I would want to use standard size RPM ball cups as that’s what I ran back in the day. Most likely will be a shelfer so don’t need a ton of adjustability just to look right.
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
How do the Lunsford titanium buckles compete the the associated team titanium? I see the as team turnbuckles for $7 a pair on Amazon
In performance on the track the Lunsford are probably no different at all but they are made from grade 5 ti, made in the USA, as well as lifetime guaranteed. Can you tell by driving the car they are better? No. But they are, at least IMO, much better.
JosephS
Post by JosephS »
GoMachV wrote: Tue May 11, 2021 4:12 pm In performance on the track the Lunsford are probably no different at all but they are made from grade 5 ti, made in the USA, as well as lifetime guaranteed. Can you tell by driving the car they are better? No. But they are, at least IMO, much better.
Thanks. Those are solid reasons. The price I found vanished so currently the lunsford parts are also the cheapest parts for upgraded turnbuckles.
Make sure to try direct, by calling or emailing. You might find better pricing that what you see advertised. Not sure if they have fixed map pricing or not.
JosephS
Post by JosephS »
GoMachV wrote: Wed May 12, 2021 1:06 am Make sure to try direct, by calling or emailing. You might find better pricing that what you see advertised. Not sure if they have fixed map pricing or not.
Thanks for the tip. The sets of pins are quite competitive in price, but I’ll need a discount on some loose pins since there is no rc 10t set.
If you call, Barb or Scott can put you a set together for sure. Great people 8)
Return to “RC10 Truck Forum”
