lunsford titanium
- DMAT
- Been thanked: 4 times
lunsford titanium
Im going to be ordering a full hardware set for the rc10. My biggest question is it worth upgrading parts to this material? Is there any advantage over stainless steel with a good finish? I'll have to determine what all screws I actually need but is it worth the money?
im guessing its either that or I go with this set here.
http://www.rcscrewz.com/product_info.php/p/ass017-associated-rc10-stainless-steel-screw-kit/products_id/1415
- flipwils11
- Been thanked: 19 times
Re: lunsford titanium
I'll be interested to hear what you thinik of these. I have a set of the titanium screws for my Tamiya Avante build (tamiya part #) but have never tried them on anything else.
- Has thanked: 170 times
- Been thanked: 23 times
My XXXT Matt Francis has a complete set of Lunsford Ti. I shed some weight for sure.......................not sure you need to lose any weight. Excellent Bling factor though!!
Alloy will not be as strong as Ti and alloy will corrode in a very subtle way if the anodising gets scratched off. Probably not an issue but worth bearing in mind.
GARBO 1/8
it's really your call. It's more expensive and doesn't corrode, and it's lighter. if you need those characteristics and don't mind paying the price, they are a good buy.
I am fortunate enough that I have a bunch of stainless hardware that I've collected over the years, so I use them almost exclusively(I use #2, #4, and 3mm) but anything larger like the 8-32's, I use the aluminum ones from associated. Mcmaster-carr sells hardware very cheaply in volume, so when I need something new, I get 18-8 stainless which is more than strong enough for these cars, plus no corrosion.
- DMAT
the other set was stainless steel so corrosion is sorta meh between the two.
as to not using aluminum, I've had too many screws tear up. Id just prefer a stronger metal and the look im going for can be accomplished by titanium or stainless so thats where im at.
i need to call the people with that other shop and ask about the screws though to make sure they have a polished finish.
- DMAT
now that ive finally got a chance. it looks like most of the screws that go in the car.
well the issue im coming up with is there is a complete screw set listed in the parts list and its only 49 screws. But looking at all the other screws listed for the car, it totals a lot more than 49 at 110. when i look at the exploded view, im getting right around 49 minus the transmission screws. So the question is what should I go with? If im buying titanium, the price can jump up a whole lot more than needed.
on a side note, since most screws are 4-40 or 8-32, I havent studied up on screw sizes but the 4 and 8 are diameter in mm and the 32 and 40 are threads per inch?
- Has thanked: 1129 times
- Been thanked: 3919 times
Keep in mind some screws should not be aluminum, stainless, or titanium. With steel you have a little give, with titanium and stainless you tend to break them more than bend them. I don't like to use anything but steel for shock bolts, front tower bolts, and nose plate/braces. Just my preference, I am not Cliff Lett!
- DMAT
Gah, after looking at all the screws. The prices at lunsford is just insane. most screws needed for the rc10 are needed in increments of 6 while lunford only sells in sets of 4. gonna end up costing $10 for each type of screw minimum.
I get the bit with steel but this is to be a shelf queen so im not too worried about running it often and needing to hold a lot of strength.
- DMAT
Its not Lunsford but i did find a titanium screw set.
http://www.hobbyetc.com/item.cgi?part_id=25402
Shipping is a little pricey
- askbob
DMAT wrote:Its not Lunsford but i did find a titanium screw set.
Nice find. That price ain't bad at all.
- DMAT
If the picture is any bit accurate, It should be much better than what I received from rc screws. Clearly your getting a much wider variety of screws that should better fit the car.
For the price, your probably getting your money's worth if the material is of good quality. about $0.30 per screw. lot less than lunsford $1.22 per.
I'm almost tempted to return my rc screws set but I can always stand to have extra hardware.
- 2306 Views
Last post by Y'ernat Al
- 1282 Views
Last post by teman
- 703 Views
Last post by justinspeed79
- 762 Views
Last post by frgna
- 567 Views
- 1666 Views
- 25 Replies
- 2108 Views
Last post by RichieRich
- 20 Replies
- 3088 Views
Last post by TRX-1-3
