Phil Davies’ Procat replica build
Andyb78
Post by Andyb78 »
I’ve been working on this Phil Davies replica Procat build for the last few months, working from the feature on the car from the Radio Race Car magazine. It’s slowly getting there and I’ve tried to get all the small details correct with the metal plate behind the front gear box adjuster, front roll bar mounted under the top deck and rear shock mount brace. Just have some wiring to finish off, the missing wing and battery decals should be here next week along with the alloy eccentric bearing housings, correct early type front upper arms and one way front shafts. After that I just need to find a KO ps87 servo and booster box plus the alloy transmission housing and servo mount posts. Both of which I believe were “pete’s awesome products” parts. I would also like to replace the black gearbox side plates with a better set if I can find any.
And finally with my two other Procats.....soon to be joined by a fourth!
Return to “Schumacher Forum”
