Rc10t rear dogbone alternatives?
Goldpan
Post by Goldpan »
I have built mostly buggies. Recently i finished building rc10gt electric conv and rc10 t. I have heard of the axles breaking whether dogbone or cvd. I am trying to find out if there are any other options without doing some extreme overhaul . Thank you
Has thanked: 264 times
Been thanked: 2018 times
Re: Rc10t rear dogbone alternatives?
As in breaking the shaft? Unless it were some odd event, I'd find that hard to believe.
Breaking the drive pins at the outdrives and/or axles? Sure, because they were worn thin. Worn outdrives and axles could also put some undue stress on them.
I've got a Kyosho car with solid plastic dog bones and a Traxxas with plastic slip shafts, that both hold up pretty well. Outside some freak event, breaking a metal dog bone isn't something I'd even consider.
RC10th
Has thanked: 50 times
Been thanked: 1492 times
Post by RC10th »
I wouldn't worry about broken shafts, while it does happen it's not common.
Make sure your slipper is set up so it slips before any damage is done.
Return to “RC10 Truck Forum”
