https://www.flickr.com/photos/188036560@N02/49796747822/in/dateposted-public/
I replaced my kyosho's outrage msc with this hobbywing 1060 esc and i was wondering where i should put the esc connector. It is strugling to go to channel 2 and if i plug it there the batt plug remains empty, with the old msc the on off switch was there. If i must plug it to channel 2 the batt remains vacant?
Thanx
Esc connection to reciever
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: Esc connection to reciever
It gets plugged into channel 2 and nothing goes in the battery slot. Make sure the white wire goes to the inside. You may have to get an exacto and slightly shave the bottom corners of the plug so it plugs in nice.
- RC10th
I would recommend F/B/R which is Forward, Brake and Reverse. Much easier on the gearbox and is quite a bit more drivable.
- 523 Views
Last post by DerbyDan
- 742 Views
Last post by Mango
- 1368 Views
Last post by Kobur
- 1528 Views
Last post by shodog
- 1350 Views
- 1464 Views
Last post by MOmo
- 302 Views
Last post by Brat
- 788 Views
Last post by tecnica2001
