B4 diff in B3 box
- Been thanked: 6 times
B4 diff in B3 box
Is it possible to fit a B4 diff in B3 box?
I've got two ball diffs for my B3 but want to swap over to a gear diff for carpet. Unless the B3 ever came with a gear diff will a B4 one fit?
- Ronbo
- Has thanked: 23 times
- Been thanked: 63 times
Re: B4 diff in B3 box
I thought the B4/T4 top shaft could fit to use the newer slippers in the B3, or is that just for the stealth gearbox? i too am planning on running a b3 in 40+ mod for fun, 10.5 to start ... i havent tried it yet to see. i have a plain T4 gearbox to try...
- Been thanked: 19 times
Top shaft is the same. The differential is different though. It will only fit B2, B3, T3 model trans case.
The final drive ratio is different also. 2:40 (b3) vs. 2:60 (b4).
Current:RC10T, T3 FT, GT Blue Tub, GT FT, GT2 FT, GT5, RC28, SC28, Micro RS4.
Previous:B2, B3, B3 FT, 10T pink chassis, GT FT, TC3, TC3 FT, RS4MT
Tamiya TA02, Thunder Tiger TS4N pro, Kyosho VoneR, Emaxx, MX4, MP 7.5, 7.5 Kanai.
I've done the top shaft conversion on my B3 and T3, well worth doing. You can also then use a B4 gear cover, easier to find and more robust than the B3 one. At the moment I'm running a 13.5 in my B3.
Is that a direct fit? Need one for my T3.
Layshaft fits straight in, just don't put the spacer on like when it's fitted to a B4.
The gear cover won't fit over the T3 clutch though, but will of course fit if you use the B4 clutch.
- 1085 Views
Last post by greene-r74
- 2850 Views
Last post by coxbros1
- 1781 Views
Last post by CamplinP
- 47 Replies
- 8842 Views
Last post by KidAgain
- 1062 Views
Last post by Phin
- 1949 Views
Last post by Diggley
- 2688 Views
Last post by Chewbacca
- 785 Views
Last post by RC10th
