cutting / routing G10 ?
rctenracer
Been thanked: 81 times
Post by rctenracer »
Hello all hope everyone is having a great summer. I ordered a set of 63551 wide arms from shapeways for a RC10 so I can run B4/B5 hex wheels on the rear. Little concerned about the durability of the shapeways arms. That said I have a scrap piece of .25 " G10 that I can get two rear arms out of. My plan is to make a template of the rear arms and route new ones out of G10 using a carbide trimming bit. Just wondering if the carbide bit will cut G10 or melt it before I dive in any further.
Been thanked: 3919 times
Re: cutting / routing G10 ?
You won’t melt it, but you may burn it. You may want to rethink it before taking the time to try. With the way the g10 is laminated, it will want to split very easily on the hinge pin hole. I cut g10 daily.
You can pick up a chunk of 1/4” delrin fairly cheap and it will take abuse a lot better. The problem then is cutting it without melting. I use an Amana 0 flute bit to cut these at very slow rpm and moderate travel speeds. Still working on the jig for drilling the hinge pin holes and arm screw holes.
mikea96
Has thanked: 659 times
Been thanked: 878 times
Post by mikea96 »
Are you getting into the suspension arm business Jeff? :lol:
rctenracer
Thank you for the info.
mikea96 wrote: Wed Aug 14, 2019 11:56 am Are you getting into the suspension arm business Jeff? :lol:
I can do the cutting side without any problem. The drilling side is a problem...lol
mikea96
Post by mikea96 »
Yes that would be a little more difficult.
rctenracer
Update to my first post . Received the arms from shapeways and they seem to be very durable .
Users browsing this forum: User avatarGoMachV, No User AvatarGoogle Adsense [Bot] and 5 guests
