New Electronics in XX4
Not really specific to Losi, but I'm having trouble with the modern electronics in my XX4. When I punch the throttle, there's about half second delay before I get full power. To be clear, the motor starts immediately when I punch it, but it's no where close to full throttle. After the half-second, it jumps up to full speed. Running Hobbywing 17.5T motor and ESC. Checked sensor cable and it seems fine. Also, checked punch control setting in ESC and that's not it. Any ideas?
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
Re: New Electronics in XX4
My first thought goes to the battery. Is it a pack capable of producing the necessary power and is it fully charged and all connections good? As mentioned, I would also check the ESC programming and radio settings. I've had a couple bad sensor cables over the years, so maybe try another one. If the motor and ESC are new, there's always that chance that something is defective. If you have another motor, try it. Then try another ESC. Of course, this is all assuming that the issue is electronic and that the diffs and slipper are properly adjusted and that the belts are in good condition, etc.
Matt
- 4017 Views
Last post by mamadoesntletme
- 559 Views
Last post by mikea96
- 2347 Views
Last post by SFC K
- 1019 Views
Last post by m2fit4u2
- 514 Views
Last post by lowrydesign
- 1180 Views
Last post by jamin
- 648 Views
Last post by karnivool
- 727 Views
Last post by fastang
