J-Car DD transmission RC10???
- KidAgain
- Business Member
- Has thanked: 513 times
- Been thanked: 431 times
Need some help with this thing guys first didnt realize cant run a bulkhead the shock tower bolts to the trans no biggie, second my dogbone ears do not fit into the axle stubs??????? I tried various models I had and third do these use a standard spur gear or something special.
One of my other concerns once assembled I can move the drive assembly back and forth with slight force here is a video, is this normal??
https://youtu.be/0Jk33vfDiag
Thanks a bunch guys..
Jake
Jake
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: J-Car DD transmission RC10???
This is what the shock tower for that trans looks like. Camber link holes are built in. We manufacture these reproductions if you end up needing one.
As for the dogbones, if they are original parts this was common. There was a line in the manual I’ll see if I can dig it up
- KidAgain
- Business Member
Wow nice man unfortunately I want to use my DS custom G10 shock tower and it will work since I can use the bottom two outer holes for the camber links but the 93t spur it came with is huge and I may put a relief in like the tower you posted or run a smaller spur....................GoMachV wrote: ↑Tue May 07, 2019 9:04 am This is what the shock tower for that trans looks like. Camber link holes are built in. We manufacture these reproductions if you end up needing one.
The dogbone thing I will wait for your response not sure what to do thanks bigtime man..
If I am wrong with any of my assumptions please speak up guys..............
Jake
This is the line from the manual about the problem with the bone and the axle.
- KidAgain
- Business Member
I will try and lightly sand the edges of the dogbone pins and hub carriers and see what happens if that doesnt work I will revisit here.....
How about the play side to side what do you think normal?
Do you have any literature for these
Looks like it just needs shims to me. Probably 5mm diameter. Traxxas makes some pretty cool fiber washers that would work.
I don’t have any literature, we only deal with the reproduction shock tower and chassis.
- KidAgain
- Business Member
Thanks man, no one else on this site knows about these things?
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
The side to side play is typical. You'll actually need shims with an 8mm ID to correct it.
Also yes these did use standard spur gears. The diffs used in the J-Cars were modified Thorp and MIP diffs for the Kyosho Ultima...they had a groove cut out into the pressure plate to fit standard diff rings used by most pan cars.
- KidAgain
- Business Member
Phin any idea where I can get these shims from, as I was setting up my transmitter the car started to accelerate on the stand and carved a slight groove on the plate when the diff moved side to side without the shims kind of upset about it but no problems just cosmetic.Phin wrote: ↑Sun May 12, 2019 9:50 am The side to side play is typical. You'll actually need shims with an 8mm ID to correct it.
Looks like I’ll need a 1mm shim to take up the slack.
Thanks
Jake.
- KidAgain
- Business Member
Found some shims with an 8mm i.d. from associated in case anyone needs them for their J-Car trans.....
#21141 - local hobby shops have one or none so ordered through Mcmaster-Carr, hate the wait game..
- 778 Views
Last post by B4maz
- 35 Replies
- 5843 Views
- 941 Views
Last post by bscotti
- 1512 Views
Last post by tizeye
- 2835 Views
Last post by enziobodoni
- 2638 Views
Last post by rctenracer
- 5834 Views
Last post by Phin
- 1219 Views
