M I P RC10 Belt Transmission
Hi Guys I need some help I purchased a beat up RC10 that has a 1988 MIP belt drive tranny. Trouble is that I think the tranny hasn't been assembled correctly and does not run smooth at all. Does anybody have or know where I can find the original assembly sheet for this diff?
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: M I P RC10 Belt Transmission
pictures would be great, but to my knowledge, only A&L and Trackmaster made belt drive AE trannies. MIP was a 3 gear - pre stealth trannie.
better guidance can be given if we know exactly which one you have.
Sorry my bad..there is a decal on the side of the box it came in that says Hyper-Drive don't know where I got the MIP from..sorry
Tizeye
Tizeye
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
do you have a belt on the spur gear or on the diff, inside the tranny? A pic would definitely help tohether with more details about your problem...
Come and visit the stable
It's on the spur gear..to the pinion(of course) on the outside..came with several different sized spur pulleys? and different sized belts and it still fits inside the original RC10 gear cover..yep I'll get some pic's taken..
Cheers
Tizeye
Cheers
Tizeye
There's a thread in here somewhere on how to build a 6 gear the right way, the hyperdrive just goes where the spur and pinion are correct?
Mark
Yep exactly the same..cheers I'll see if I can find that darn thread..
- Asso_man!
have a look here for the Hyper-Drive belt: http://www.rc10talk.com/viewtopic.php?f=35&t=6854 (last pictures of the thread) and here for rebuilding your 6-gear tranny with Jim Halsey: http://www.rc10talk.com/viewtopic.php?f=7&t=3748
Note that if you plan to actually run your car with the Hyper-Drive set-up, you'll either need a reverse motor or swapping the motor plate to the left...
hope this helps!
hope this helps!
Cheers for all of the help guys..I'm going to put it in a Big Boys Toys sprintcar when it arrives..will keep you guys updated
Tizeye
Tizeye
- 3106 Views
Last post by Lowgear
- 2838 Views
Last post by Lou0151
- 2109 Views
Last post by polarbear
- 2675 Views
Last post by RichieRich
- 1461 Views
Last post by rc10johnny
- 2402 Views
Last post by scootmike
- 34 Replies
- 3892 Views
Last post by treehugger
- 1160 Views
Last post by aip47-2008
DotNetDotCom.org [Bot] and 7 guests
