B6 question- turnbuckle&ball studs
Forum rules
NomadRacer
Has thanked: 81 times
Been thanked: 79 times
Post by NomadRacer »
If you are a "modern man", help me with some info...
What size are the balls on the ball studs (#91049)?
What size turnbuckle, the threads, is used on the ball cups (#91722)?
I'm looking at putting together something and exploring options.
Thanks in advance.
Bum on Direct Deposit
works92
Has thanked: 85 times
Been thanked: 32 times
Re: B6 question- turnbuckle&ball studs
Post by works92 »
The balls are 5.5mm diameter,
and the turnbuckles threads are 3mm ones.
hope it helps
NomadRacer
works92 wrote: Sun Nov 18, 2018 3:43 am The balls are 5.5mm diameter,
hope it helps
Thanks for the reply. B6 hardware is not going to work, I'll keep thinking of an alternative plan.
Users browsing this forum: No User AvatarAmazon [Bot] and 6 guests
