Axial Servo Horn
Axial Servo Horn
The teeth on the servo horn went bad. I’m a newbie so I’m not sure do I need a new servo horn specific for this servo or will any 25 tooth horn work?
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Axial Servo Horn
horns are all compatible, just find one with the same splines as stock (axial is pretty modern for us here- I cannot confirm their spline count). Keep in mind you may need to drill the hole out a bit or choose a hole thats close to the original. If you can add a servo saver instead (Kimbrough recommended) it will help keep things from breaking as easily.
- Basher67
- Has thanked: 44 times
- Been thanked: 160 times
I wouldn't install a servo saver on a crawler. Your splines most likely failed because of torque, not impact. Crawling requires tight precision steering control at times and a servo saver will not allow you to maneuver as well. The answer here is an aluminum servo horn and eventually, if you dont already have one, a metal gear high torque servo. I say all this assuming that your axial servo is in an axial truck. If you're using an axial servo to steer an RC10 buggy, ignore all this and follow GoMachv's instructions.
Good call, I hadn’t considered the vehicle being an axial as well- these newfangled contraptions confuse us old folks
Thanks for the info! I replaced the worn servo horn with an alum one. Works great!
Also, I’m using this in an rc10 re-re
- 1568 Views
Last post by Rich Trujillo
- 1273 Views
Last post by Medved
- 1518 Views
Last post by PerryCodes
- 1310 Views
Last post by THEYTOOKMYTHUMB
- 906 Views
Last post by SmallScaleSmitty
- 708 Views
Last post by LTO_Dave
- 25 Replies
- 4324 Views
Last post by GodSpeed
- 48 Replies
- 10253 Views
Last post by XLR8
