Servo horn issues
- Been thanked: 7 times
Servo horn issues
Hi all,
I have a worlds re release kit and have pretty much built up as much as I can. I am being sent a replacement top shaft as it was one of the incorrectly machined ones.
That aside the next issue that I have is that none of the servo horns seem to fit the servos I have available.
I have a savox sc0352. And a feetech FT5679M, and from what I have found out both take a 25t horn........which should mean a futaba one.
All of the horns supplied seem too small. Has anybody else had this issue, and if so how did you fix it?
I don't have a spare horn for the savox ( it came without it) and the feetech seems to have a huge bulky thing. Anything that saves me a massive badge job will be much appreciated
- slotcarrod
- Been thanked: 45 times
Re: Servo horn issues
You have to push it on with a good amount of force.
Rod Littau
Jeez you weren't kidding! Stripped the internals of a good plastic servo trying to get it on. The metal geared servo fared better and if went on after softening the plastic in a little hot water.
- 1479 Views
Last post by BenW
- 1569 Views
Last post by Rich Trujillo
- 1518 Views
Last post by PerryCodes
- 1310 Views
Last post by THEYTOOKMYTHUMB
- 906 Views
Last post by SmallScaleSmitty
- 1761 Views
Last post by surgetek
- 2381 Views
Last post by GodSpeed
- 1134 Views
Last post by kaiser
