Could use your guys help with how I should gear my truck now that I went brushless.
Motor: Turnigy Trackstar Outlaw 13.5T (2886KV)
Trans: Stock stealth with the B4 Slipper mod
Tires: HPI Yokohama Geolandar (4.05" diameter)
Some initial research has told me that I want to keep my FDR and the tire roll-out as close as possible. Playing around with this calculator: http://www.rcuniverse.com/community/gearwizard.cfm it looks like running a 88T spur and 17T pinion will get me pretty close to 1:1 with the tires that I'm using. Can anyone confirm this? How would this work with my motor? Thanks in advance for your help!
RC10T Brushless Gearing Suggestions
- i crash cars
Re: RC10T Brushless Gearing Suggestions
based on the T4.2 manual for a 13.5 brushless motor and maintaining the FDR from a 2.6 ratio to a 2.25 ratio trans, a 17/87 pinion/spur is a good starting point (do they make an 88t spur?)
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Joe is on the money with 17/87. Normally since the tire size is the same between all stadium trucks (within reason) the ratio is all you need to be concerned about.
84 ÷ 19 × 2.60 = 11.49 (T4.2)
87 ÷ 17 × 2.25 = 11.51 (RC10T)
- i crash cars
- 1249 Views
Last post by Justjoe
- 1270 Views
Last post by HotRod716
- 1186 Views
Last post by pumpkinfish
- 851 Views
Last post by Rustbucket
- 933 Views
Last post by Bmw1tech
- 2387 Views
Last post by MOmo
- 9605 Views
Last post by kiohio
- 1276 Views
Last post by 1911Colt
