t4.1 brushless Gearing????
Forum rules
i have a associated t4.1 rtr with the stock brushless setup and was wondering how high i could gear it? I went from a 18t pinion to a 26t pinion and the esc and motor definatly run warmer then before but nowhere near dangerous. The battery however seems to run warm now not hot but warmer then id like, its a cheap lipo 4000mah 15c battery. So if the car isnt too bad now if i back down to a 23t pinion would the batery still be too warm?
Re: t4.1 brushless Gearing????
When ever you lower the gear ratio ( bigger pinion lower spur) you are pulling more amperage from speed control and battery and the motor is dissipating that energy in heat. If you have stock electronics be careful. I would stay under 23 tooth pinion. Motor shouldn't get hotter than 160.
- 857 Views
Last post by Rustbucket
- 9616 Views
Last post by kiohio
- 2404 Views
Last post by MOmo
- 1277 Views
Last post by 1911Colt
- 1043 Views
Last post by kaiser
- 1948 Views
Last post by daz_75
- 2036 Views
Last post by Stumpy
- 20 Replies
- 3653 Views
Last post by tecnica2001
