Works 91 runner
Works 91 runner
Hello.
I am very lucky I own a works 91 in very good condition on my shelf.
Is it reasonable nowadays to run it on astroturf just for fun (no race) from time to time ?
I think to run it with lipo and a brushed motor 14T.
I know that this machine was very strong but will it brake on this grip surface ?
- works92
- Has thanked: 85 times
- Been thanked: 32 times
Re: Works 91 runner
Hi eugine,
I would rather say mostly wear than break something
no doubt the diffs will wear faster
the rest of the transmission (dogbones, belt...) maybe too,
but i don't no how a 14t powered by lipo push/brake
be careful with the front arms and steering blocks, they're not so durable.
- olfrjf
Re: Works 91 runner
Eugine, i have done the same thing than you one time on astro, i think it wasn't a good idea, the car is in showcase now
Olivier
Olivier
- olfrjf
Re: Works 91 runner
Sorry, it was on carpet and not astro, indoor for me.
any
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Works 91 runner
Actually it pushes much harder, too...
- Less weight to move around
- More voltage, both at low load and a lot lot more at high load!
Paul
Re: Works 91 runner
I did this question because I run a 6 gears with a 17T and an RC10T3 with a 5.5T (yes 5.5 LRP) without any issue.
My T3 is the local champion this year
For practice I have a B6.
But it will be fantastic if I can drive this Yokomo once a time in my life
- olfrjf
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: Works 91 runner
I say go for it and have fun. If it breaks, fix it. That's not the end of the world.
Re: Works 91 runner
Hi that's obvious if I break it I will fix it.
But I need to know if there are any parts that are very rare to find and with a big chance of breaking them.
- works92
Re: Works 91 runner
If you find and put a plastic/delrin front bulkhead then you can try to find Drescher front arms, they're bulletproof.
but you have to change c-hubs
at this point you can also upgrade to RPM or alu steering hubs
- Mr. ED
Re: Works 91 runner
What I meant was: this was a competition level car in its days. If you don't go crazy and drive halfway descent you shouldn't have to worry about breaking stuff.
- 1259 Views
Last post by Alex B
- 29 Replies
- 2846 Views
Last post by ericsp2
- 3819 Views
Last post by Lavigna
- 39 Replies
- 4525 Views
Last post by RETRO R/C
- 1045 Views
Last post by NRG
- 1534 Views
Last post by Mad Racer
- 1075 Views
- 2410 Views
Last post by Synergy
